My new ARX has failed the Vic RWC as it "needs a new" RH tie rod... ;)
Ben at Northshore, who I bought the car from, is trying to find one, but if he has problems, does anyone know if any Aus delivered Nissan would use the same part?
Open to any suggestions...
https://www.sau.com.au/forums/topic/267321-m35-tie-rod/
Maybe the 350Z.
https://www.sau.com.au/forums/topic/267321-m35-tie-rod/#findComment-4559001
My new ARX has failed the Vic RWC as it "needs a new" RH tie rod... :P
Call Ferntree Gully Nissan 9758 4444 & speak to either Vaughn of Stephen in Parts.
Ask them which cars share the part with the NM35.
They will be able to tell you there and then.
Then Ben will pay for the part & install :)
Edited by iamhe77
https://www.sau.com.au/forums/topic/267321-m35-tie-rod/#findComment-4560258
Then Ben will pay for the part & install :P
Well the good news is that they know what it is...
The bad news is that they don't make them anymore, they take an existing one (in stock), and modify it to the correct specs (required parts not in stock). To do that, they need to order parts from Japan... 2 week wait...
Let's hope Ben can find one..
https://www.sau.com.au/forums/topic/267321-m35-tie-rod/#findComment-4560428
No good man, I hate hearing things like that. At least you got a quick answer though!
https://www.sau.com.au/forums/topic/267321-m35-tie-rod/#findComment-4560456
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
