I have for sale left over stuff that were once used in my car (a 1996 series 2 r33 gtst) but have now been removed and replaced with different things.
1: Front GTR grille badge off a R33, brand new unused. $100
2: Nismo white gear knob, brand new unused. $50
3: Purple oil cap will fit gtst and gtr engine unsure of others, slight use, no marks. $75
4: Standard throttle body off gtst, used. $70
5: Two factory blow off valves, used. $35 each
6: Two factory cross over pipes, one is powdercoated blue with a turbosmart bov adapter on it and the other with a HKS style bov fitted, but not using factory bov holes, used. $100 each
7: R33 series 2 air flow meter with pod filter adapter on it, used but perfect working order. $150
8: R33 gtst washer bottle, no motors. $30
9: R33 gtst standard computer. $150
10: R33 gtst standard intake both top and bottom, used. $150
11: R33 gtst series 2 fuel rail with sandard injectors, used, but in perfect working order. $200
But i am also open to trade for anything of interest at around the same price of each item.
I am located between geelong and melbourne, victoria. But i am willing to post at buyers expense.
Please post here or p/m me.
Cheers,
Bernard.
post-34355-1240827734_thumb.jpgpost-34355-1240827792_thumb.jpgpost-34355-1240827832_thumb.jpgpost-34355-1240827887_thumb.jpgpost-34355-1240827915_thumb.jpgpost-34355-1240827948_thumb.jpgpost-34355-1240827985_thumb.jpg
Edited by Bubble
https://www.sau.com.au/forums/topic/267352-r33-series-2-parts/
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
