  • Replies 192
Update:
Well the Silvia came and went…
I must say I could not wipe the grin off my face watching a silvia get crushed!!!!!
Also picked up a new toy to use as a parts bitch!
the busted gtr was a bonus!
this gtr im building a drag car out of it
when i mean drag car i mean ill pull the engine out change the oil then put it back in
its going to run 9's
before i get a chute for the bitches
Edited by fatz
yea the old silvia
smashed ( written off)
welded back to gether by mr dodgy... who bought it off me to wreck
then sold with a rb26dett with high mounts
lol
im sure its still around
did good skidz!
on more information
jennas car has a strut brace now
good for 9's i would say!
Edited by fatz
fatz you're sick mate. car looks as pretty as you do. but way tougher with the k-sports and aqua strut brace.
now how about you give me back my tip you cnt. I still have your hat as hostage, your ears must have just about frozen off by now. don't make me post it back to you flap by flap... lol.
got some big arse brake air deflectors for jennas car so the brakes will last the 6 hour race at philip island
also getting some alloy spacers for the rear cradle and a hicas lock
in time ill remove the usless hicas when i get the spare steering rack modded
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
