I'm sure the Wolf has been discussed before, but only recently have people started speaking of the version 4 for Skylines. I was wondering about some of the more fundamental differences as they apply to Skylines, rather than the maximum amount of power you can get from each of them. Does anyone know anything about the following questions?
1. Does the Wolf do closed loop mode as efficiently as the PowerFC? I know that in the past most other ECUs couldn't compete with the PowerFC in fuel economy (cruising) mode.
2. Does the Wolf work properly with the climate control and HICAS etc?
3. How do the hand controllers of each compare? I've not really seen either of them, so which one is easier to use, and do they both show you enough on screen to make for a useful additional dash gauge?
4. If you have an older Wolf, can you upgrade it to a V4, and if so how much does it cost?
5. Does either of them have any fundamental advantages over the other? I know that the current Wolf has more load points, but looking at cars tuned with PowerFC's power curves, the amount the PowerFC seems to be more than adequate. I think having more tuning points would just mean more work.
6. How much is the Wolf with hand controller?
That's about all I can think of now. Thanks in advance!
https://www.sau.com.au/forums/topic/26738-wolf-3d-v4-vs-powerfc/
  • Replies 175
Wolf3D V4 is $1395.
Hand Controller is $220.
Memory Cartridge is $32.
The big advantage of the Wolf3D that I can see is its lifetime warranty and standard built in Boost control that apparently works very well. I have heard that the PowerFC boost control isn't very good. Also the number of load points which if used and tuned properly 'should' I would think give slightly better fuel economy over an ecu without as many load points. i.e Microtech.
Seriously down load the EMS Tuning Software.
Copy the second disk *.cab in to the first disks directory and install it.
You can download the EMS Tuning software from
http://www.wolfems.com.au/home
Just a pitty about not having a knock sensor.
Jim. When you check out the software and look at the closed loop mode options I think the fuel economy will come down to how good the tuner is and if they really know what they are doing when it comes to setting the inactivity under load settings etc.
Originally posted by T0nyGTSt
Jim,
You can see my FC + HC + Datalogit usb addon anytime next week.
T.
Tell me more about the Datalogit usb addon - For ECR33 right ?
I thought that wasn't avalble yet ....... ??
Tell me where to get one - I want, I want !
Tony, my PowerFC + Commander was supposed to be here last week so hopefully it will arrive soon enough, but I've never heard of this Datalogit thing before. What's it for?
Joel, what's the memory cartridge for? $1620 for the unit+hand controller isn't too bad I guess, but still a few hundred bucks more than I paid for the PowerFC+hand controller. I guess I'll just have to wait and see if the PowerFC can do everything I need it to do.
The memory cartridge allows the maps to be saved and loaded externally.
What is the Boost controller worth for the PowerFC. This would then make the Wolf3D a pretty good buy I would think for some one without a boost controller. OR an RB20DET which has to pay $1500 just for the AP Engineering PowerFC.
I've made a quick list from the Software.. Not sure if everything is 100% but it should give you a rough idea.
Boost Control
Turbo Timer
Air Temp
Engine Temp
Internal MAP & External MAP/MAF
Load - MAP, MAF, TPS
Closed Loop
Thermo Fan
Rev Limit (Yellow & Redline)
Fuel - Engine Temp, Air Temp, Battery Voltage Compensation
Ignition - Engine Temp, Air Temp Compensation
It looks like its got everything bar the kitchen sink. Which turns out to be the Knock Sensor.
This Wolf3D really has got me thinking as honestly for $1395 it is pretty good value. Is there any other ECU that comes close? I.e Has boost control, Closed Loop, MAP/MAF, Turbo Timer.
Well, I've already got a GReddy Profec boost controller, so the Wolf has no advantage there.
The thing is, the Wolf costs $1600 with hand controller and has no knock sensor. I'm paying around $300 less than that for a PowerFC with Commander (2nd hand). If I could have found a second hand Wolf for less than that I might have considered it, but there didn't seem to be any around at the time I had the money ready.
All I can do is see how frustrated (or not) I get with the PowerFC, and if so then contemplate selling it and getting a Wolf.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
