I am looking at selling my EBC as the ECU I have chose has an EBC built in.
If in SA and its an R32 I am willing to install it, or if its an R33 and you know what to do with the solanoid I will give you a hand.
I will show you how to fully use it so that you can get on the road and know what you are doing.
I have made it hidden on my car as I have the hand controller detachable by the use of a ps2 plug. Looks very neat and tidy and can be removed if you get pulled over by police quickly due to the handcontroller being detachable.
<span style='font-size:8pt;line-height:100%'>
Features:
Boost Unit - Can display boost in PSI, bar, KPA, and kg/cm2.
Four Channels - Has four different programmable boost settings.
Boost Gauge and Peak Hold - This boost controller has a built in boost gauge and peak hold that can be display in booth graph and digital form.
Boost Warning and Limiter - This is a safety function allows the user to set the amount of boost decrease in the event of any over boost. Warning in visual display and audible warning.
Scramble Boost - The scramble boost feature allows the user to set an increase or decrease in boost for a desired amount of time.
Manual or Automatic Boost Setting - The SBC i-D allows the user to set boost both in manual and automatic.
Automatic - Sets boost directly, just dial in desired boost setting.
Manual - Sets boost in ration, this setting will give maximum boost response. Recommended for high boost vehicles and large turbo.
Speed Map - The SBC i-D has the ability to control boost by speed (Power Meter i-D required). This function allows the user to fine tune the boost according to the speed of the vehicle. speed Map is set up by the different boost channels, the boost controller will switch channels automatically according to the speed of the vehicle, Speed is transfer from the Power Meter i-D by the infrared connection between the SBC i-D and Power Meter i-D.
Record and Replay - SBC i-D has the ability to record and replay any information that was display on the SBC i-D. The SBC i-D can also replay information on the Power Meter and any of the optional data that is display. Replay can be fast forwarded and replayed in 2x and 5x.
</span>
It is still currently installed in the car.
If you are in SA and would like to see it working before purchase, that can be arranged.
Offers?
https://www.sau.com.au/forums/topic/26739-blitz-sbc-id-ebc-installed-if-in-sa/
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
