1997 Rvr Hypersportsgear "r" Spec - Evo Running Gear
1997 RVR Hypersportsgear "R" spec
Located in Perth - contact me here or via pm.
Pictures below - advertised here and a couple of other forums
1997 RVR Hypersportsgear "R" spec AWD , EVO running gear.
2.0ltr 16valve twin cam intercooled turbo charged (td05), 5 speed, 184kw.
PRICE : priced to sell at $12,000ono (stock standard ones are advertised more than this - i could start at 15k but i rather sell quickly) - needs a couple of very small things (might fix if i have time) which ill tell to the serious buyer but this car has been the most neat/quality/complete car i have owned. Some may remember the car from awhile back, the mod list should give it away where it came from. Car has been Featured in Performance magazines, all quality parts have been used.
the mods:
*ARIAS forged pistons
*Eagle Forged con rods
*HKS metal head gasket
*Aftermarket lifters
*HKS GD Pro twin plate clutch
*XSPEED custom intake pipe with HKS super flow air filter
*Custom GENIE 3" turbo back exhaust with Prof vrs cs muffler
*SARD R2d2 BOV
*HKS circle earth wire system
*GREDDY oil catch tank
*ARC titanium manifold cover
*HKS EVC electronic boost controller
*APEXI EL2 Boost and exhaust temp electronic guages with control unit in a GREDDY Dual pillar mount.
*RSPEC turbo timer
*BLITZ power meter SJ
*RSR lowering springs
*RECARO SR seats
*EVO 7 17x8 wheels
*XSPEED Balancer shaft removal kit
*stainless steel piping with HKS silicone clamps.
*Climate control integrated into glove compartment.
*Dark tint
*Alarm
*Custom shopping list on sideskirts :down:
*Pioneer tv head unit with in dash cd player - custom made box on top of dash.
Rockford forsgate punch amps (installed in custom unit in back), splits (rockford in rear, PHD splits in front), Dimension 1 farad cap, Dynamat used in car.
plus more, but that's all i can think of at the moment.
Engine was rebuilt about 10k ago, only has 97 on the clock.
all the luxuries - climate control/all electrics/cup holders/storage compartment's/spare ciggerate lighter for an eski or what not in the back.
Standard features Limited slip differential, Rear spoiler, Rear window wiper, Driver airbag, Anti-lock braking system, Rear seat lap sash belt, Side impact protection bars, Central door locking, Steering wheel height adjust.
Rear seats can fold all the way back straight like a bed.
Sit's 4 very comfortably. Goes/stops/handles quite well.
Has PERMITS for exhaust, catch can, fmic/piping, pod filter and guages.
pics dont do it justice, but you get the idea
cheers.
Edited by JesseJ
  • 3 weeks later...
  • 3 weeks later...
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
