Hey guys i am looking to upgrade to a KKR430 and 550cc injectors in my VL with an RB20det, i am wondering if it will be okay to install the mods and drive to where i can get my ecu re-mapped? I would have to drive about 400kms, but i am thinking it wouldn't be a problem if i drove sensibly.. What do you guys think?
Cheers
https://www.sau.com.au/forums/topic/267398-is-it-safe-to-drive-my-rb20/
The turbo shouldn't be an issue if you run it at low boost however the car will run very rich if at all with the 550cc injectors. I am putting a Z32 AFM and GTR injectors on mine soon, I'm buying an eManage Ultimate which allows you to set which AFM your running as well as injector size/latency, its not perfect but will work if you just need to drive to get the car tuned.
Well considering you would be putting double the fuel in through the injectors, no.
You will foul the plugs, wash oil off and glaze the bores. Not good for the motor at all.
400kms is a long way, I bet it will take you 2 tanks as well.
