Hey guys, i sent my app via fax, and paid the membership fee, but I think I may have put down my log-in username rather than my member username.
Can you let me know if the app is being processed ok.
Thanks
Thanks
Hey mate,
Send a PM to "Shell" in case she doesn't catch this thread. She's sometime on pretty late, so don't be to concerned if she doesn't get back to you immediately.
Cheers
Bobby
Don't worry, I'll find you.. if i cant find the username, i search the log in name, or part of your email address, or other various ways, in the Admin section :D I'LL HUNT YOU DOWN! lol
Its the people who write a "username" but haven't actually signed up to the forum yet who screw me :P
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
