Pontiac Is Officially Dead
  • Replies 43
Wow...
I wonder if the Pontiac brand was doing well in the states??
Pontiac was popular with rental car companies, and old timers. in the 90's besides that it was rubbish
the last decent Pontiac was in the 60-70's,( the Adelaide built car was the best build quality by far)
shame to loose the oz ,local jobs but they did it to themselves, GM just didnt look into the worlds economy and driving factors of smaller cars, they kept building massive fuel guzzlers for soccer moms. now Detroit,Michigan is a ghost town compared to the past.
agree Buick needs to go too, caddy too, just make it one company to reduce the exec overheads,
I'm glad I moved to Oz and not stuck in USA , I feel for my family and friends back there and I'm sure Oz is still in store for more $$$ depression coming soon
you would be mistaken to think its going to get better in a few months...lol
but its a real wakeup call to the world
Geez.... the US built ones must have been shit heaps then! :P
Holden at Elizabeth haven't been making large numbers of the G8 for last few months anyhow, still any market lost is a huge deal for manufacturing jobs here in Aus
Edited by TALBO
seems companies are using any excuse they can get their hands on to lay off jobs at the moment
peter's icecream here in WA was bought out by cadbury's i believe
all 180 factory staff lost their jobs about the space of a day
i mean REALLY
you buy an icecream factory
and
then
....nobody works there??? who's gonna make the icecream???
but yes
we'll see wat happens with holden
it's a sticky one cos people need to spend money not get into debt and you can't pay cash for a new holden!
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
