Timing Belt is a MUST at 100,000kms.
Might as well do your fan belts.
The usual things,
Oil (Which you have done)
Oil Filter (Which you have done)
Fuel Filter
Air Filter / Air Pod (Just a clean will do)
Spark plugs (Which you have done)
Radiator Coolant flush
You could do your Gear Box and Diff Oils...
Check Brakes (Pads / Rotors / Calipers)
Your Tyres would need a check (tread level and air pressure level)
Tighten up bolts and over general check over of the car in and out.
The main things anyway, but if still unsure, take it to your mechanic and see what they say as they should know what is fully required at 100,000 kms.
The usual things,
Fuel Filter
Alright thanks...
It is a good start.. I will take a look over everything and do what i can then take it into Nissan to complete the ods and ends..
as stated, do the timing belt, mine is at 96000 now and the timing belt is starting to look a bit cracked and perished (got the new gear on the way)
kudos motorsport sell a 100,000km service kit.
How much do they sell the Kit for??
Awesome!!
Sorry to hijack the thread, But do you know whats included in the kit?? (Off the top of your head)
http://www.skylinesaustralia.com/forums/Ni...0,000km+service
Nissan RB25DET (R34, C34 Neo Engine)
Price: Starting From Only $567.60
Standard Kit Components:
Genuine Nissan Timing Belt
NSK/NTN Idler & NSK/NTN Tension Bearing, Tensioner Spring
Genuine Nissan Cam Seals
Genuine Nissan Front Main Seal
Genuine Nissan Water Pump
Genuine Nissan Thermostat
Genuine Nissan Oil Filter
*Please note that NSK & NTN are the original equipment manufacture (OEM) of the Nissan timing belt idler & tensioner bearings.
100,000km Service Kit, Nissan R34 25GT (RB25DE, Neo 6) $455.40
Contained within this service kit are the following:
1 x Genuine Nissan Timing Belt (Option to Upgrade to Heavy Duty Trust/GReddy Item, Please Select Below)
1 x Trust/GReddy Cam Gear, Intake, Adjustable (Optional, Please Select Below)
1 x Trust/GReddy Cam Gear, Exhaust, Adjustable (Optional, Please Select Below)
1 x Genuine Nissan Water Pump
1 x Genuine Nissan Thermostat
2 x Genuine Nissan Cam Seal
1 x Genuine Nissan Crank Seal
1 x Genuine Nissan Tensioner Bearing Spring
1 x Genuine Nissan Oil Filter
1 x NSK/NTN Timing Belt Idler Bearing
1 x NSK/NTN Timing Belt Tensioner Bearing
  • 1 year later...
is this kit still available?
It is - but doesn't doesn't include as much and costs more
Nissan RB25DET (R34, C34 Neo Engine) - Starting From Only$492.80
* Genuine Nissan Timing Belt (Optional Upgrade to Trust/GReddy or Gates Racing)
* Genuine Nissan Water Pump (Optional Upgrade to Nissan N1 Item, Where Applicable)
* NSK Timing Belt Idler Bearing (Ex RB20E)
* NSK Tension Belt Idler Bearing
* Genuine Nissan Tensioner Spring
* Genuine Nissan, or Aftermarket, Cam Seals
* Genuine Nissan, or Aftermarket, Front Main Crank Seal
Ref: http://www.skylinesaustralia.com/forums/Ni...vi-t137554.html
thanks man, i will check it out
  • 6 months later...
Just wondering how you went with your service? I'm attempting it on my 34 also and I have found leaky cam seals. Problem is I need to get the VVT actuator off. Do you know if the nut is reverse thread or not?
There is a notch on the Allen key head which sometimes means reverse thread, either way it's bloody tight. Like to know how you went?
Cheers
Mark
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
