hey guys just would like some help on where this pipe came from? the picture is how i brought the car, and its just has a peice of hose on it with a screw blocking it??
it is an oil pipe, and leaks everywhere??
Edited by Buddy
https://www.sau.com.au/forums/topic/267440-where-should-this-pipe-go/
Its obvious this is a aftermarket turbo that you have on this car...
The factory baby turbo is both WATER & OIL cooled as it also requires water as a cooling source being a ball bearing (but ceramic turbine wheeled) AND as from the photos you have supplied, the turbo that is now on there is only oil cooled (most probably a thrust bearing type that only requires oil). I can only assume that its the water/coolant line being blocked off as its not being used.
The factory turbo has 4 lines attached to it, OIL IN, OIL OUT, WATER IN, WATER OUT.
The current turbo has two lines : OIL IN & OIL OUT.
DO THIS : let the car cool down, un-do the block-off nut at the end of that hose and see what comes out of it, if its water or coolant, then its sweet (even tho it should really be connected back up to the other water hose for a continuous flow) BUT if its oil, then it's not right !!
Edited by smok74
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
