hey guys
got my 32 about 2 months ago and been ironing out a few problems it had
since fixing other things i have noticed that i have:
an injector that has a small leak and is dripping small amounts of fuel onto the inlet runner (cant see it dripping but can see a small pool of fuel sitting under the injector and smell the fuel
and
after you go for a spirited drive its not a fan of a steady idle, yes i have cleaned the aac a couple of times now and i thought it was gone (had timing problems including a broken cas bracket :P which is now fixed). Its a strange problem as the car runs fine all the time now but after i went for a burn yesterday and i pulled over to change the timing and let it idle which started becoming more and more erratic (low revs then high revs then lower then higher) and it eventualy went so low that it stalled itself. i adjusted the timing and drove home. when i got back i let it cool for a while and it started doing the same thing. 1 thing to note that i was rumaging around and found the cold start valve was completely blocked off and unblocked it (cold start has been working perfectly ever since)
1 last thing
its got an rb25 turbo on it which usually runs ~10psi but i noticed that in 3rd at ~6k rpm it was getting on for 13psi, could the thin walled silicone hose that goes from the hot pipe to the actuator cause this (expanding under pressure maybe)?
many thanks if anyone can shed some light on anything as its starting to get a bit annoying
Tom
https://www.sau.com.au/forums/topic/267455-couple-of-rb20-questions/
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
