selling my spare sr20det
complete block, inlet mani, throttlebody, hoses
missing rocker cover, waterpump exh mani/turbo, cas and injectors
its a red top had 150,000k's
was overheated, has dmg to the No.1 conrod
thats why its cheap $200
pm me or 04154949235
located in skye 3977
300zx twin turbo engine unknown k's (under 100k i would say)
came in with a spun bearing, and has since lost 1 of the main caps
has most of the bolts on's still on, manifolds, injectors, coilpacks, small section of a cut loom, cas. you can see it all in pics
was being set up for a gemini, engine mounts to suit
comes with trust manifolds (have been reversed and tacked to fit gemini)
$200
front Tanabe shock with 5zingen springs NO TOPS will have to use your std tops to use em $100
and r32 gtst indicators $40 and a few spare interior peices
alotta pm's about the indicators
one has a small crack in lense hardly noticable
and the wires are missing from the other
if you want them just call
im in SE vic, skye
$40 for the 2 of them
Edited by luker
  • 1 month later...
  • 4 weeks later...
still got the blinkers first one to call get them on hold till you pick up
tanabe's ill post but ill have to wait till my next day off
im looking for a low pair of S13's front ill trade for em or anything i got
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
