These are off my brothers car which topped out 337wheel kw (about 450Hp) on 1.4 bar (20.5 psi) after we installed the injectors. Please note this this is on pump fuel and with the finial power run and MAP I chose to drop ignition timing to compensate for the inconsistent fuel we have in sydney
No 1/4 mile figures have been done at the creek, however with the Data pulled out of the MoTeC ECU 11.2 and 11.1 were the figures at 195 kph (about 121 mph).
These have been on the car for a year and a half up until a couple of weeks ago these were only run on a measly 1 bar boost due to lack of fuel however we have since fitted 1000 cc injectors, pump etc etc to run up to 20 psi. They ahve done about 21,000 Road Klms
These bad boys are on 20Psi by 4,000 RPM and provide punch all the way to 8500 RPM where power does start to drop off slightly with the current set up.
Best used with aftermarket IC, ECU, Exhaust, cam gears, further intake and exhaust ect etc. If you have the mods you can push an extra 4 psi and achieve more grunt however I chose not to do this.
These are genuine NISMO turbo's not made up local units with full steel shaft that is larger then standard, larger compressor wheels and duel roller bearings.
Selling due to upgrade that should put us in the mid ten ohh bracket
Please do not reply with stupid offers as these cost over $4800 new and are an absolute steal at $2300
If you would like pic's please email me
If amosite is genuine, which i am sure he is, these puppy's are an absolute bargain!
I was lucky enough to purchase a car with BNR34 N1 turbos already fitted in Japan along with a host of other gear. I can vouch for amosite in that these turbos (even though slightly different to my own) are ultra responsive and make a huge heap of mid range torque and response.
I am so happy with my turbos that i dont think i will ever look to upgrade as i cant see any other turbo out performing these type for pure street use...They are driveable, useable and provide a nice wide meaty power range...
Good luck with the sale and for anyone interested, these turbos are the crem del a crem for any serious street car. And if you dont belive me, just look at the latest HPI 7, the top low mount turbo GTR from Phoenix power garage used BNR34 N1 turbos to the tune of 630 odd PS at the wheels!!!
Basically, buy these turbos and you are guaranteed atleast 400RWHP (providing you have pump inject. etc), for a tad over $2000 its gotta be worth it!
  • 2 months later...
Hi,
I noticed you are after a set of N1 turbos to suit an RB26. I've got a couple here in good condition (zero shaft play) for sale - asking $2000. Let me know if you are interested.
Regards,
Chris
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
