long story short, i am looking to upgrade my brakes as i want better stopping power, and i can get hold of a set of GTR34 brakes with discs, just wanna know if it will bolt straight on? now i know that i need to trim the hat(the plate behind the disc? not sure what they called) to fit the bigger diameter disc, but i wanna know if the caliper will botl straight on to the existing mount or i need to custom made some brackets to hold them in place.
also, can anyone tell me how good is the gtr34 brembo work? i havent tried them but have compared mine to an EVO8 and they are like 1000 times firmer/stiffer than mine.
any help will be good.
cheers
https://www.sau.com.au/forums/topic/267480-gtt-upgrading-brakes/
34 gtr brembo work about 25-30% better then Gtt brakes over all, and they should bolt straight on, (sure it only fits a gtr disk since it is bigger then gtt's in dia.)
and also you need a diff. off set wheels to fit that in, since the gtt stock wheels wont fit
(EVO8 and they are like 1000 times firmer/stiffer)= both the GTR and GTT, are towards the loss side compare to evo or sti, (doesnt mean the brakes is shit) that is jsut different style the brakes have in different cars , forexample my 04 cocolla's brakes are firm but come to stopping power that is way less then the gtt, but any the GTR brakes are for sure feel better
all so if you want to improve the brake feel and brake power (firm/stiffer) you can put in a set of good pads, Stanless Mesh brake lines, cusco brake Cylinder stopper . all that not only will help the feel but, should have better performence too
Edited by SKYGTT
thanks for your reply, it is very much appreciated, it has cleared alot of stuff in my mind, i am in the situation of thinking weather to get this brake set or not, i guess now i will compare prices and performance in order to come up with a solution.
cheers.
What pads are you currently running in the GT-T? I noticed a massive difference upgrading just the pads on mine if yours still have the stock pads they are absolutely shocking pads compared to even Ferodo Formulas which have a decent friction coefficient for the $125 trade price an end. My car went from feeling worse than my daily in some situations to a very confident powerful stopping force. If you have the money something like the Ferodo DS2500 is a nice pad, a little pricey, but still cheaper than changing calipers, rotors etc. I upgraded my R33 brakes to R34 GT-T ones and was disappointed with the results but it was the pads letting me down as the calipers still had the stock Nissan pads. Once all changed it was a completely different braking experience felt like you were braking in a different car.
Also what fluid are you using? You will get a slightly better pedal feel, but more importantly it will not boil!, running decent fluid in a properly bled system its amazing how many people upgrade their rotors, pads, caliper etc and then run $5-$10 brake fluid. I currently run the Motul RBF660 and it has never let me down by boiling on a spirited drive. Yes its $40 a bottle and you really need to buy two to do a proper flush out and bleed but its $80 that can stop you loosing all braking power when they get too hot talking from experience here, luckily I don't mind drifting as I was forced to drift around a tight bend to make it around the corner when the brake fluid boiled on me and I lost all braking power. I look at it as cheap insurance and it doesn't need changing that often so its relatively cheap overtime.
If you are still running the stock lines I would keep them did the whole braided line upgrade really wasn't that impressed and after reading autospeeds testing of stock vs braided lines I could see why as the difference in flex is minimal, so minimal its probably impossible to really feel on your foot with a shoes on etc so I ended up swapping back to stock ones R34 ones on my R33 (so they were slightly fresher rubber).
http://autospeed.com/cms/title_Braided-Bra...79/article.html
For anyone reading this with a R33 the best mod I found (yes im giving away my secret as everyone that has met me with a r33 has heard lol) is to fit a R34 GT-T brake booster to the R33. Its a tight squeeze as its almost twice the size just clearing the clutch master and gives you a massive increase in pedal feel. Anyone who has driven cars that are only a couple of years old and in particular european cars + new hyundais would have noticed they have massive pedal feel with huge braking force. In my job I became curious as to how these cars had tiny rotors, relatively small calipers yet fearce stopping power. Upon popping the hood on them they all had very large booster/servo units which lead me to my mates shed where he has every model skyline and we noticed that the R34 GT-T booster was twice the size of the R33 GTS-t! They are reasonably rare as not many wreckers are wrecking R34's yet so may almost be cheaper to buy one new than wreckers but 100% worth the effort. Combine that with good pads and fluid and you will be very happy with your braking force. I too was chasing the Brembo trail till I read about the relatively small improvement they would give given all the financial outlay and effort.
Edited by nigelswazi
thanks for your valuable information, i am still using stock lines with URAS street pads, havent beld the oil yet but will do it soon coz i need to change my pads very very soon. will give the motul oil a go and see what differences are there.
cheers.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
