Hay guys, what do u get from 0-100kms? Mine's R33 GTST(Auto) from 0-100kms is 8.1 sec. How is the result for GTST, is my car in good condition or bad condition? Becasue my pervious GTS could get it within 10 Second(MT). So i just wonder is that result very bad for a turbo car?
Cheers
Steven
https://www.sau.com.au/forums/topic/26752-what-is-u-guys-got-from-0-100kms/
yeah mate i think so! So u think my car is on not too good condition? Becasue actually since i bought that car, no matter how hard i accleerate the car(Kick down), and i didn't feel the turbo is coming.( Becasue that is my first turbo car, and i never sit on a turbo car) So just wonder when the turbo is coming, how is it feel and how can i know when the turbo is coming?
I know in the Dash under the RMP in R33 have got a little clock, it like +7, and -7! And when accelerate hard it will raise. I wonder, when it will be raise to +7, becasue even i kick down , the maximum i could achieved was between +2 to +4 ! what is yours one guys. What do u guys got, if u kick down?
Cheers mate
Steven
i don't really understand what u mean. Sorry!
But i did shifting the gear manually, even from 0-100kms, started from 1-and 2 gear. And i also couldn't achieve +7.(Max i could go is +4- +5) If on the highway, i did push the O/D button and power button, then kick down from 70kms to 140kms. It also couldn't achieve it. Wonder why? is my car have problem or the turbo goes down?
Last thing is can you please tell me how does the turbo works?(Becasue it is my first turbo car) is it noticeable?
Thanks for the advice!
IC, thx bro! Make me so upset b4, i thought my turbo have something wrong. So if i want to achieve +7, then what can i do, please show me. Becasue i really feel my car even got the turbo, but it's not so powerful.
By the way, can u please tell me, how to determine the turbo and the engin is in good condition?
Cheers bro
pentae :P
steven dude "Becasue i really feel my car even got the turbo, but it's not so powerful."
that doesnt really make any sense :) surely you can find some one who knows a bit about these cars that can help you first hand! because i cant understand you bro!
to up your boost to get your +7 get a bleed valve fitted. very simple about 100$AUS. But factory boost gauges can be faulty, i had mine running 12psi, and the factory needle hardly moved into the +zone for some reason.
Thx dude, u know why i said like that bro? Because today i killed by one GTS25 on the traffic light. that's why i thought perhaps my turbo has something wrong or either my engine is in not good.
Because it's a long story. Since i bought that car, i need to repair lots of thing. But anyway, i really appreciate you guys the valuable advice.
cheers bro!
Cheers bro
The main question is y did u buy an auto for??
By stall it up i mean using your left foot ump on the brake hard so the car isnt going anywhere...then using your right foot apply some throttle.
The revs will climb ad the engine will start making boost, if you let go of the brake the car will kind of cataplut from the standing start. Try this method a few times, with different amounts of reves, even wheelspin to see the quickest way
I have an Auto and its fine. Just stall it up using the brake to about 2000rpm then plant it. If you want to go faster turn overdrive off so it rides out 3rd gear all the way. My 0-100 time is like 5.5 sec using the stall method. Make sure the power button is on so it will redline every gear and it should be better. And getting +4 on the stock boost is good probaly about 7psi (guess?).
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
