Off an R34 Non-turbo, but will apparently fit the airflow meter of all R32-34's turbo or non-turbo.
Consists of a stainless steel right angle pipe, with threaded PCV attachment and connection for A/C idle tube, with T-piece.
HKS Pod & filter cage....the foam will need replacing as it is starting to look a bit sad.
Any offers over $100 accepted, will have a picture posted on Monday 13th October.
Dan
https://www.sau.com.au/forums/topic/26761-hks-pod-filter/
hmm pipe looks interesting. but doesnt look long enough to run from turbo to afm...can you measure the rough length of it - hang on ~ I am assuming you would even separate it, would you?
Thanks
https://www.sau.com.au/forums/topic/26761-hks-pod-filter/#findComment-574202
