After having a look at the various threads on people replacing their OEM swaybars with thicker whiteline one's and the overwhelming positive response they receive I thought it wouldn't be a bad idea to do the same with my NA R34.
I'm not sure if it's just my car, but it appears that the NA R34 coupes did not come with a rear swaybar as standard!!!
So my question is, if this is the case, has any other n/a r34 owners fitted rear swaybars to their cars?
If so what are the parts required (other than the swaybar duh), any modifications required to fit and approx cost?
Also what diameter swaybar people went with and the part # would be an excellent help to me :D
Thanks in advance to those who respond...
Resh
Oh and before anyone says "do a search"... I have and can't find any info on NA R34 swaybars. After learning of differences in suspension set ups between the n/a and turbo's I thought I'd ask here before dropping a couple of hundred one something that doesn't fit.
Edited by resh
https://www.sau.com.au/forums/topic/267635-na-r34-rear-swaybar/
i would recommend doing both front and rear.
fronts go for a thick 24mm one (adjustable or fixed doesnt matter), usually the largest fixed one you can get.
rears go for something around the same size maybe 22mm but definitely an adjustable for the rear.
the swaybar settings will be dependent on your coilover setup.
normally you will be experiencing some understeer or oversteer.
harden up the rear swaybars to induce oversteer
soften up the rear swaybars to induce understeer
that's pretty much it in a nutshell, the setup is of course a little more dynamic than that and highly dependent on tyre grip!!
swaybars will ultimately reduce body roll when doing high speed turns. the weight is distributed to the inside wheels and you therefore put more tyre grip on the road.
hope that helps
How much more harsh is the ride in an R34 after fitting both front & rear H/D Sway Bars ? (whiteline)
I don't 'think' that sway bars make the ride harsher, rather just stabilise the load between the two sides of the vehicle.
I can't really comment too much on the before and after with sway bars as I also had 30mm lowered king springs fitted at the same time as my whiteline bars, but I can definitely say that it made a difference to the body roll.
The combination of spring/shocks and tyres/tyre pressure used would make a lot more difference to comfort.
I am in no way a suspension expert but that is how I understand it.
Ah Nathan you've had some fitted?
I'm aware you have a sedan but do you know what was required in order to fit the swaybars?
Did you just use the same part numbers at the turbo and it was more or less plug and play or did you have to add anything else that the NA was missing?
To be honest, I'm really not sure... I got a quote from Fulcrum for springs sway bars and fitting + alignment and they ordered the parts. They may be the same? Sydneykid will probably be able to answer that question for you. Or give Whiteline a call.
GTR parts tend to have different mounting points. I believe another member on this forum has found out the hard way after purchasing parts for his na r34 only to find that he requires GTR parts (as the GT-V's have the same 4wd setup). Unsure about r33's but if the r34 is anything to go off I would be pretty certain they are not compatible.
Also for everyone else who is interested I've shot off a quick email to whiteline in regards to the NA R34 compatibility and what's additional components are required (if any).
I'll post up their response once I've received it.
I'll try dig up my invoice from Fulcrum to see what part numbers are on it. If I recall there was mention of GTR on a couple of parts, I just thought maybe its just the way they entered the inventory on their system, perhaps a part suitable for most models... but maybe it is in fact different.
I'll see what I can find later tonight.
It's amazing how many companies who are supposed to know these things will term interchangeably use any skyline variant. For example the place i took my r34 to get coilpacks and a general service done printed R34 GTS on the invoice. Pretty sure there is no such thing as an R34 GTS!
If you can just get the part numbers later on Nath I'll cross reference the whiteline website to see if they are indeed parts interchangeable with the GTR.
Bring it up in suspension. I can't seem to find it anywhere! which is strange cause I keep all my car stuff in a folder...that I try not to look at lol I wouldn't have thrown it though as it had all the alignment results etc.. so if it comes up somewhere I'll post up.
We just put the Whiteline bars on my 32. We just took the rear back off and put the standard one back on.
Reason being my lap times were no better in some case's worse.
The bars we got have 2 setting's (I dont know if they are soft/med or med/hard) we tried them on the far end setting, no good, moved them both to the inside setting, was a little better but still heaps of exit oversteer. The front feels good but the rear doesnt. We only have basic setup, no coilovers, tyres that are getting old.
I read that its better to have a stiffer front and a softer rear so we will try that and see how it goes. Problem is we just dont have the money to go testing so it will be race day before I know if its good or bad. Which is NOT good.
Visit My Website
Edited by johnGTS-t
Wow - that sure is news to me... I thought all "modern" cars regardless of brand etc.
Reason being my '83 Bluebird (not a TRX) has a stock rear sway bar as well has the R31 skylines out there....
My R34 n/a (non- gt-v) sedan has them stock - I imagine the R34 coupes will have them stock due to being more "sportier" so to speak.
I just want to clarify are you refering to the rear strut brace (this is the brace you see in the boot and rarely comes with with almost any car) as opposed to the rear swaybars (which are "under" the car)?
Also what diameter swaybar people went with and the part # would be an excellent help to me :banana:
Resh
ah, good point Mark but surely Resh knows where he should be looking.
I've had the adjustable Selby front and rear swaybars and whiteline pineapples in my car for over 12 months now (from memory) they joined the Aus-spec Tein SS's. I installed the rear bar and pineapples myself but had to take the front swaybar to a shop to put on. I couldn't believe how much the swaybars improved steering feel and stability but they also increased ride harshness. the front bar is on the softest setting and the rear bar is on medium (again from memory). the teins are also on their softest setting.
i really can say, 'the car handles'. the amount of corner speed i can maintain is awesome and it always feels planted giving remarkable feedback.
i remember a cruise i was on towards the end of last year up north of brisbane going through some good twisties to get to the final meeting spot I had a GT-t behind me which couldn't keep up although I'm unsure of the GT-t's level of mods and drivers experience.
also as a reminder my car is a GT-V.
Mark I can understand how absurd it sounds that an R34 of all cars would not have it at standard but I assure you mine does not have one (and yes, I'm not confusing this with a strut brace). At first I thought that the owner in Japan must have removed it but after hours of searching this forum I found one or two others who have also realised they do not have one.
Of course there is that possibility that the Japanese owners of all of our cars were deluded and thought it would be a clever idea to remove the sway bar, but if they were that way inclined they wouldn't be driving skyline's in the first place!
For anyone who is keeping an eye on this thread I still haven't received a response from whiteline or another suspension/handling mob I've emailed but I'm sure the coming of the working week will bear some fruitful responses.
More info regarding the ride harshness please Reggi :P Been thinking about fitting a set.
You can PM me if you want. Cheers.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
