All good mate. Just making sure :P
Mark I can understand how absurd it sounds that an R34 of all cars would not have it at standard but I assure you mine does not have one (and yes, I'm not confusing this with a strut brace). At first I thought that the owner in Japan must have removed it but after hours of searching this forum I found one or two others who have also realised they do not have one.
Of course there is that possibility that the Japanese owners of all of our cars were deluded and thought it would be a clever idea to remove the sway bar, but if they were that way inclined they wouldn't be driving skyline's in the first place!
For anyone who is keeping an eye on this thread I still haven't received a response from whiteline or another suspension/handling mob I've emailed but I'm sure the coming of the working week will bear some fruitful responses.
Found the invoice!
Here goes with an extract:
BNF24Z Swaybar-h/duty Blade adjustable
BNR11Z Swaybar-h/duty Blade adjustable
KDFL-101 NISSAN SKYLINE GTR NZ Fr LOWER
KDRL-61SP NISSAN SKYLINE R33 GTR Rr LOW
SPF0984K UNIVERSAL SWAY-BAR BRACKET
Looking at this site, the swaybar codes match up as being front and rears for R33 and R34 RWD.
http://www.skylineowners.com/forum/showthread.php?t=112382
The KD Codes are for the king springs. I listed them above for informational purposes since parts for a R34 N/A Sedan components were in question here. Hope that the codes are accurate, basically transposing what I have here.
Hope this helps.
  • 5 weeks later...
Just an update for anyone who is wondering what has been happening with this...
Whiteline have replied and surprise surprise they aren't sure if the R34 GTT part will fit!
However, the part they have said should fit is the same as Nath has listed which is BNR11Z which comes with all the required components except the D-Bush saddles (which I'm assuming is the universal sway bar bracket listed in Nath's list).
Here is a link to what the whiteline kit contains http://www.rcephotos.com/photos/Whiteline/BNR11Z
I'm just about ready to bite the bullet and go ahead with it all, just need to work out a wrecker to get those D-bush saddles from (as they are present on the GTT) and where I can get the swaybar from at the best price.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
