Auto or Manual ???
If your looking for an Auto gearbox I have a Jatco RE4Ro1a 4spd auto with overdrive which came out of my R32 GTS which is identical to the R33 GTS-T auto box only difference is the speedo drive but I have an R33 one in the box already..
The gearbox will need an overhaul tho as the pan had metal contamination (more than likely just needs clutch packs and a reseal) ... But I have a Stage 2 shift kit to go with it so you can upgrade the valvebody...
Only reason I didn't do this box up is I bought an R33 GTS-T series 2 box already with a modified valve body which had 130,000km on it
The Box Comes with Torque converter , flex plate (worn teeth will need a new starter motor ring), and R33 tail shaft
But thats if your looking for an Auto if your looking or a manual box I can't help ya sorry dude
https://www.sau.com.au/forums/topic/267636-rb25-gearbox/#findComment-4563516
