FOR SALE Skyline Turbo Parts
Item 0: R31 Turbo setup everything u need
Turbo: T3 hi flowed with .73 A/R rear internal gate the dump pipe has been high temp coated
turbo hasnt been used since hi flow and rebuild.
comes with all banjo bolts and oil/water lines.
Manifold: VL turbo modified for external gate and the spacer plate welded on so bigger turbos can be bolted on.
hasnt been used since modified.
Injectors: Denso 550cc good condition were flow tested before i brought them from SPG garage
Computer: nistune daughter board ready to install in ur standard rb30 computer i have the licence and the software just needs to be downloaded from the website
$2000
good for around 230-240kws at the wheels
dont really want to separate.
item 1: Fuel Pump and Surge tank setup to suit r31 turbo with all hoses and and clamps
items are brand new never used Bosch 044 and 1.5L surge tank
comes with everything in the pic all u need to do is wire it up
$400
Item 2: set of 17x9.5 black drift teks with tyres, not sure what offset
good condition couple of scraches thats about it
tyres are:
235/50 dunlops and 235/45 federals with about 60-70% tread
$1100
Item 3: G4 hydraulic handbrake
$260
Item 4: Pair of Bride Copy race seats with custom r31 rails
brand new condition bolt straight in r31
$400
Item 5: battery box with kill switch and positive and negative wires. positive wire long enough to run under the car to the front. has battery bracket and bottom plate brand new never been used.
$150
PM me or Phone 0437492045
https://www.sau.com.au/forums/topic/267638-fs-r31-turbo-parts/
