Hi Guys, did a bit of an upgrade on my skyline and have these parts for sale now. I prefer pickup and Im located in brisbane:
  1. White faced Cluster Set: $220
    One of the tags on the clear plastic cover has broken off
  2. GTR Steering wheel: $80
    Has normal wear for its age
  3. GTR32 Factory Fuel pump: $120
  4. Turbosmart dual stage Boost controller: $140
    Does not come with toggle switch
  5. Pioneer Head Unit: $120
  6. Factory Cam gears: $30
  7. GTR32 Injectors: $300
  8. r32 Boss Kit (New) does not fit GTR:$40
  9. Supra Boss Kit (New): $50
https://www.sau.com.au/forums/topic/267648-32gtr-parts-for-sale/
Hi Guys, Price update. want these gone.
  • White faced gauge Cluster = $200
  • Factory Fuel pump = $100
  • GTR32 Injectors = $250
  • Supra Boss kit = $40
  • Turbosmart Dual stage boost controller = $100
  • 3 weeks later...
  • White faced gauge Cluster = $200; Decided to stay with standard cluster. was for 1990 GTR
  • 32GTR steering wheel = $80; put aftermarket steering wheel on
  • Factory Fuel pump = $100; upgraded to bosh 044 pump
  • GTR32 Injectors = $200; Upgraded to sard 700cc
  • GTR32 coil pack = $150; upgraded to splitfires
  • Turbosmart Dual stage boost controller = $100; upgraded to Vipec boost controller
  • Pioneer head unit = $100
  • 32 Boss kit = $30; Does not fit GTR
All items still up for grabs. They were all in working condition when they got pulled out for upgrades. Items going cheap. Someone must want them. Will post at buyers expense but prefer pickup in Brisbane.
intrested in steering wheel. pm sent
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
