Hey Guys not sure if anyone has already posted this, but ill ask anyway
I want to know if anyone has put Scissor Doors/Lambo Doors/Butterfly Doors etc etc, (FOR COUPE 2 DOOR) what ever you want to call them on their V35
If so i was after some pictures too see what it looks like as i am interested in getting them.
Thanks for any help guys, Also if anyone knows a place in WA that would do this for me.
https://www.sau.com.au/forums/topic/267661-vertical-doors/
scissor doors shouldnt be too hard to put in place as ur just replacing the hinge
scissor doors would be awesome i also was considering them myself however best if u look into the compliancy laws if u dont want to get stickered by the cops.
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-4563737
It's not just replacing the hinge. you got to cut into the body of the car. lots of work. The Hinge is huge!.
Personaly i wouldn't get them even if there where free. They do look cool when up. Works like this. You open the door about 1 1/2 foot then get out of the car and pick up the door and lift with both hands (becasue it's heavy) so everyone can see you got them. Unless your buff then you can do it sitting in the car with one hand.
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-4563780
i have also heard that the door is attached to the sidewall of the car, i.e NOT where the old hinge was, but on that panel, and it has been known in many occasions to bend the sidewall because of continuous use (weight),...this was not on a v35 thou.
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-4563925
  • 2 years later...
Sorry to revive an old thread but was just woundering if anyone has done the scissor door mods since this post was started, im looking at doing it in the next few months and i have found some bolt on kits that do not need any cutting into the body links are below.
http://www.ebay.com.au/itm/03-up-Infiniti-G35-Bolt-on-Lambo-Vertical-Doors-Kit-/320707626095?pt=Motors_Car_Truck_Parts_Accessories&hash=item4aabaa046f
http://www.ebay.com.au/itm/Infiniti-G35-03-07-2-4DR-Bolt-on-Lambo-Vertical-Doors-/320704675353?pt=Motors_Car_Truck_Parts_Accessories&hash=item4aab7cfe19
as it is on a gas struts the doors should open on there own like a bonnet does or atleast make it easy to open the doors.
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-5877822
I have fitted lambo door kits before on a late model celica. Big job, requires taking the whole front end off the car. And very fiddly to set up. Did require some trimming of the inner guard.
If you are going to get a kit would reccomend spending the money and getting a good quaility kit.
It did look very porn after it was done!
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-5878310
One of my initial plan too. But got put off by the weight of the doors. Plus, I had to get RTA certificate to be legal which cost anywhere between $1.5k-$2.5K on top.
Definitely not good for under weight girls too.
Looks hot though. :thumbsup:
Edited by VNS 24
https://www.sau.com.au/forums/topic/267661-vertical-doors/#findComment-5879576
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
