  • Replies 184
nice meet guy!!! melways could make it a lil better..lol...despite i was the only 180 it was a good meet..cough**better than NS**cough...
cheers
LOL ns...
If it makes you feel better I have an s13 as well...just couldnt drive em both...haha, didnt you have exas? at some stage?
LOL ns...
how did u know that?? its suppose to be something that no1 knows!!! yea i did and afta that i had a wicked ET turbo and now the sexi 180sx...
uploading pics now, lol thanks for coming tubz, did anyone else see when we got to minro st car park. that red VZ commo and with it the red r34 coupe with the led taillights driving around everywhere/around our cars at pizza shop etc. looked dodgy LOL.. pics up in about 10 min :D
hahhahha that is mark aka assiran4ever (spelling) there weren't hungry!!
Did you mean 10 minutes or 10 hours? :D Hurry the f*ck up man!
Someone is a bit of an eager beaver today hahaha bet b3za is having trouble transferring images from his NEW AWESOME OMFG 10MP CAMERA PHONE...pffft who needs DSLR's these days? *Whats that 8MP SLR pffft my phone is 10*
Haha yeah I am an "eager beaver" coz I wanna see the pics before I go out :D Actually heading over to the WEST SIDE to help my mate DJ a 21st tonight. I hope all west-side girls are as hot as the ones at last night's meet :P
picsoritdidn'thappen
Thanks Antony and Beza, was a great night out!
Thanks to all that attended, makes it worth the effort to organise when we get a great turn out :)
Hope to see you at a few other SAU events/cruises.
For those that aren't members yet; you're missing out on a few more events like these, so don't delay JOIN NOW! :P
im having trouble figuring out how to transfer pics from this new phone to comp LOL... SORRY! LOLOL
:) Who totally guessed it!? Damn I'm good!
last time i follow Ferah :) got me lost and didnt even wait for me!!!
uploading pics now, lol thanks for coming tubz, did anyone else see when we got to minro st car park. that red VZ commo and with it the red r34 coupe with the led taillights driving around everywhere/around our cars at pizza shop etc. looked dodgy LOL.. pics up in about 10 min :)
red 34 was me. wasnt hungry and wanted to stay outdoors so i just followed Mark around in his bogan-mobile :P
4 door with the rb26 was tough! i want
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
