Hi all, just put some mods on my 1990 32GTR recently with 123ks. So far, I have installed:
  • Vipec ecu running 13psi
  • Blitz pod air filters
  • 3 inch catback exhaust
  • HKS adjustable cam gears
  • sard 700cc injectors
  • bosh 044 fuel pump
  • turbosmart fuel reg
  • nismo fmic
  • vipec boost controller
Everything else stock.
had the car dynoed on shell optimax and it only managed to get 192 awkw. This seems prety low to me with the level of mods i have compared to other owners of GTR's with less mods. Is there something wrong with my motor or is this figure about right? Thanks for your help
https://www.sau.com.au/forums/topic/267688-gtr32-power-level/
There is a whole thread dedicated to RB26 dyno results - a LOT with stock turbos.
Have a look through, you'll soon see what you should be getting with 2-3 pages.
thanks, I looked on the forums, and people are running more power than me with less mods. Maybe the engine is just tired and need a freshen up.
Yeh, my car got 50kw's more in rw mode than in aw mode on the same dyno lol, some dyno's allow for the awkw mode and will read like rw dyno's and some have no correction and will just read the power output at all fours.. Also some will read higher than others because the tuners like them reading that way
That's the shiet thing, some peoples stated awd are actually just adjusted to read like rwd figures, at autosalon for example
I've always wondered about the power loss.. 50kw's seems alot to lose just to the front wheels being on? How can some legitimate tuners get readings on awd dyno's that are only a few kw's different from the same car in rwd on the same dyno
Edited by GTAAAH
I dont understand why you have done what youve done to the fuel system! For standard turbos! You dont need it. Plain and simple.
For the money youve spent on the fuel system you could have bought a second hand set of hi-flows and made ~270kw.
Forget about changing the dumps, thats stupid, might as well change turbos at the same time if youre going to do that.
Yes do a front pipe and check the cat. Or go de-cat. (Best)
P.S 13psi is scary for 19 year old turbos.
+1 and +1.
Standard fuel system is ok for up to ~280kw (tho fuel pumps get tired so it is probably worth replacing that)
I just blow one of my turbos at 13psi. Conservative tune, 120,000kms. (FWIW they're supposed to be replaced every 100,000kms).
ask your tuner about it. what did he say? do a power run in RWD and see if it makes you feel better. and as above, for up to 280rwkw you can use standard injectors, standard reg and standard pump (providing it's healthy).
Yeah thanks for the advice, I'll get the front pipe and cat checked. I guess I should have asked for advice before I started tuning my car. Learning the hard way :P . I bought the GTR off one of my workmates to resell but decided to keep it instead. When he had the car, he upgraded to 3" catback exhaust. was going to change the front pipe and cat, but my mechanic said that they will be fine cause they are aftermarket. He also did Pod filters, VIPEC ECU tuned running 12psi. The car had a power output of 189awkw. So basically I made 3awkw with the added mods :cool: . Better than nothing I guess
I asked my mechanic about the power output, he said that 258awhp aka 192awkws is quite normal for a car running standard turbos. Well thats a bit of the reason why I changed them as well just to be on the safe side cause the system is getting quite old now. nearly 19 years old. But Im not too sure if they have been changed in the past.
+1 and +1.
sorry to hear that your turbo blew. what a bummer. I just hope that my turbos hold up for a little while longer
Im just running the stock turbos. I think Mark was going to run them at 14psi, but decided to run them at 13psi instead
Agreed with Femno's comments, spend money on turbo's and dumps next.
FYI i had 15psi, 262rwkw/236awkw
Car was tuned on same dyno by the way.
Was that on aftermarket turbos?? I have purchased some second hand rebuilt GTR33 steel wheeled ballbearing turbos. Just waiting on them to arrive, Its been 5 weeks and still waiting.
Stockers. Other mods (minimal) are in the thread R31Nismoid linked you to.
Turbos's dont take 5 weeks for delivery from within Australia. Contact the seller, get a tracking number
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
