Hi everyone, I was wondering what sort of an ordeal it would be to change the springs/shocks in my 32 GT-R, considering I have basic tools and would be doing it off a jack? Do I require special tools of any kind to get the job done? I really want to have a go at doing this myself if possible since finances are tight, but I gotta say I do enjoy learning as I go with these types of things! Any help from you guys would be much appreciated :)
Yeah u can tackle it at home but make sure u use a jack & good quality stands.
You will also need a spring compressor of some type.
And when completed a wheel alignment.
Cheers & have fun.
Ah Thanks Yld-Chld. Will I need a spring compressor for the back? This is the end in need first of all... Also, I'll probably be getting the springs/shocks together, so if I am swapping the whole show in one piece, is the compressor still required? Hmmm, better start scouring ebay for one just in case!
http://www.monash.edu.au/muarc/VISU/reports/jacks.html
read this and realise how few of these people used jack stands. I have seen plenty of jacks (bleed down) or someone come and twist the handle while fiddling with it and drop a car by accident. not good.
http://pandora.nla.gov.au/pan/49480/200504...eport_jacks.pdf
1.5 hours???
Did ya stop for lunch as well???
I recently had a small problem with my Bilstein Shocks, broke the top clean off while many miles from home.
Rang a couple of mates and within no time had sourced a set of coil-overs to go in my 32 GTR.
We had the old shocks out and coil-overs installed, in Hungry Jacks carpark at about 11pm in Hobart CBD.
Took us all of 25minutes I reckon.
Did the fronts at home the next day, by myself in less than an hour.
GTR struts would have to be by far the easiest struts I have ever replaced in my life.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
