I am trying to get a R33 blue slipped. Currently has a pod on it and mechanic tells me I need to get a standard air box. Can anyvbody tell me if a Pod Filter cold air induction box will pass or does it need to be the factory original set up.
https://www.sau.com.au/forums/topic/267725-blue-slipping-a-r33/
You need to track down a standard air box with filter or go and do a drive by noise test and have the car engineered.
I'd just find a standard air box. :O Check the ads on here as there is always someone wrecking a R33 or call Just Jap in Sydney, I found them very helpful.
Hey thanks guys appreciate it. I'll try to get a standard air intake. Had a bloke try to rip me off last night over one. He said I could borrow one provided I would give him $350.00 deposit and he would return $310.00 when I bought it back trouble was he wouldn't give me a reciept or anything for the money.
Beware of Ron May from Beresfield.
Seems a bit dodgy to me
Make a box yourself, if you need ill make you a template, where do you live, if you need a hand PM me and we might be able to work something out.
I charge by time, for every 15 minutes I charge 1 can of Jim Beam.
My charge to make a template is 1 x can of Jim Beam.
Also delete the name, that is a NO NO, never name someone as that is bad ju ju, if someone wants to know about someone else PM them the info, otherwise it is called slander
Hey mate, you can get it blue sliped, cover the pod with one from just jap or make one yourself, bring it down to my work and see if my boss will pass it. PM me for adress. I just got my 33 done off him so ill try asking him 4 you. Make sure the rest of the car is sweet, ie tyres lights ect. Cheers, BTW it will set you back $110 for the blue slip for the imported vehicle, you will also need a copy of the customer infromation slip. Which has all your specs for the car, you should have been given this paperwork from either the dealer or owner depending on where oyu got it. Without these you wont be able to get a blue slip.
Peeps, I think we should have a standard set of everything which members can borrow. I had a standard AIR BOX and I gave it away for free to clean my garage.....(silly me!). We most of people replace those in upgrades and give them away cheap. Once you have the blue slip you put back your pod.... I am sure of that!
Eug.
i think it depends on the blue sliper as i got mine blue sliped with a Pod Filter about a month or so ago
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
