ok, well bombtrack and i are building a ke70 with an SR20det for a drift pig.
money is not huge on this build and we're aiming for around 200rwkw @ 950kgs stripped
planning on using an stock r34 turbo we have lying around and running e85
now a pfc is obviously the best cheapish option
BUT
could we get away with just a SAFC2 & an SITC?
e85 uses around 30% more fuel and is useless with out timing adjustment so an sitc would be needed, but will the safc be able to bend the signal far enough for the fuel? i dont have any real experience with safc's
i figure both could be had for around $500 second hand so its gonna be half the price of a pfc
https://www.sau.com.au/forums/topic/267728-sr20-ecu/
$420 will get you a nistune chip + Tuner license ($220 for chip alone if some one else is going to tune it). $120 for a consult cable(Not needed if your not the tuner)
This will allow you to remap the stock ECU realtime. This will be just as good as a power FC and alot better than any piggy back system.
https://www.sau.com.au/forums/topic/267728-sr20-ecu/#findComment-4564853
R34 turbo on SR20 ...
Aren't the flanges different???
You could make 200rwkw on E85 EASILY on a stock SR20 toooobo
Ben - dont get Trent into trouble and make him advertise, just send him a PM.
Although you know what Hamish - SR20 ECU's run pig rich, so running E85 on a stock ECU might lean it up nicely - sure it might ping a bit, but it would be free :P
https://www.sau.com.au/forums/topic/267728-sr20-ecu/#findComment-4568467
BUT
you can pick up a PFC without hand controller for under $700 if u shop around, and it has a better resale value than any of the other options when ur finished with it.
https://www.sau.com.au/forums/topic/267728-sr20-ecu/#findComment-4568676
Although you know what Hamish - SR20 ECU's run pig rich, so running E85 on a stock ECU might lean it up nicely - sure it might ping a bit, but it would be free :blink:
lol... d00d that is even too ghetto for teh pig...
yeah, was thinking of using an adaptor plate for the 34turbo, as we have one lying around (and a 33 one) but after speaking to trent i'm just gonna get a 2nd hand s15 turbo
true dat, but trent has hooked me up with a nistune board in ecu an case, so i'm stoked! deal DONE :)
https://www.sau.com.au/forums/topic/267728-sr20-ecu/#findComment-4568954
