It's 5 minutes between PMs, and is currently being trialled as a solution. I might knock it down to 3 after the bot plague has settled down a bit more. But for now I'm gonna keep it at 5 mins as we're still getting signups from uncommon IP's which then don't become active on the forum.
just bear with it for a while.
You've got it half right...
But see one of the many threads on it (funnily enough, a few threads below this one!)
http://www.skylinesaustralia.com/forums/Sp...re-t265283.html
http://www.skylinesaustralia.com/forums/Ba...kz-t264737.html
:cool:
now that people are spamming to get up the 10 posts needed to pm I have a new policy. Anyone caught spamming to get up their 10 posts gets their post count reset to 0 and a suspension with warning note. or we can just flat out ban them. but surely some people will be actual genuine members who are just impatient. so we can do reset to 0, suspension/warning, and then if they do it a second time - ban.
I've been watching those spamming - seems many are dodgy - its actually exposed thing even better
I've banned a few accounts because of useless spam attempts that clearly offer nothing.
I say we make it 100 posts and limit it to certain areas!
great idea 10 is a little too low, and someone who has just joined the site and community really doesn't need to PM people as they wouldn't know anyone
since there are admins in this thread i will ask my 2nd question here, rather than start a new thread >_<
2) have adding trader comments been disabled for a bit or just mine, can a Admin please look into it, thank you
I could make it so if your post count is over 100 then it drops the time limit. If you haven't been caught out by 100 posts then I'm fairly confident that you're a regular.
  • 9 months later...
can you at least set it up so if you have over 100 posts its only 30 seconds or a minute to send another PM.... not the 4-5 minutes it is now :laugh:
  • 5 weeks later...
Hey
Any chance some of the members that have been here a while (ie. me :P ) could get this PM thing dropped? I'm PMing every one in the group buy at the moment for details and the 5 minute thing is killing me :(
Does making a donation get rid of it?
Edited by PM-R33
  • 1 month later...
Is there a way to drop this delay for paying Traders such as myself who have also been on the forum for a while now?
Running a business, i dont get alot of time to check the forum, and when i do, i can get the other forums all replied within 10 minutes, meanwhile i have to wait 5 minutes for each pm i send which is impossible.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
