My springs are hard as hell, insanely hard, and it's standard ride height so instead of getting new springs i'm thinking about cutting em.. i know this is dodgy but yeh,
A friend of mine said it's possible to take the spring off, and pull it up slightly so that one of the coils is sitting over the top of the tower part (mine has around 4 coils left over) and this will lower it without me having to cut em
I know it's dodgy but.. yeh curious if anyones ever heard of that second method?
Car is a r32 gts-t with aftermarket coilovers not sure which brand
Edited by 123456
....prefer to work on performance a bit if that was the case :P....
What are you talking about?!?!?!
Suspension is a key part of performance. What do you want to do, work on the engine then destroy any ability to use the benefits.
As mentioned above, dont be a dumbass a just do it properly.
lol, you guys buy my car and you can do whatever you want with it, ok
My car already handles better than it goes by far, i cant hardly kick the back out,
People lower their cars all the time FYI. by putting shorter springs.. it's just shorter.. and they're already tight as all hell.. either way the car sits lower.. because of a shorter spring..
So no one i'm assuming has heard of pulling the coils up top like i explained earlier?
Edited by 123456
never heard of pulling them over the strut top, and I don't understand how you could keep them in place and ensure they don't rise or fall.
plenty of people have cut springs and survived, just keep it to a decent length (eg 1 coil).
However...you said "My springs are hard as hell, insanely hard".
Cutting a spring makes it harder by the % you remove (eg if you cut one coil of 8 it is 9/8ths firmer). You will lower it but make it firmer.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
