Used parts:
6boost Steampipe manifold, high mount, T3 flange, external gate (only used for 2 months) $1000
Custom RB25 polished inlet plenum $650
Q45 throttle body $280
Z32 Air flow meter w/plug $250
ER34 RB25-NEO PowerFC + hand controller $1300
Denso 670cc injectors + rb25-neo fuel rail $950
Tomei type a poncams to suit RB25 neo $700
Splitfire Coilpacks DIS-008 $450
Carbon Fibre coilpack cover for RB25 neo $200
email [email protected]
https://www.sau.com.au/forums/topic/267738-rb-engine-parts-for-sale/
  • Replies 44
then the 260 degree in/ex 9.15mm lift are type b.
if thats definately consider them sold.
but only if 100% definate as you first stated as type a.
ive sent you an email...
consider the 260 cams sold so dibs for me.
ER34 RB25-NEO PowerFC + hand controller - SOLD pending payment confirmation
Tomei type a poncams to suit RB25 neo $700 - on hold pending payment
Splitfire Coilpacks DIS-008 $450 - on hold pending payment
hay buddy
do u still have the carbon fibre coil pack cover. if so conside it sold
pm me please
and could i have a pic of the plenum please buddy
cheers
julz
Edited by GUN_METAL_GTR32
plenum is fitted to NEO head. idle is fine, was tuned to idle at 850rpm, over 300kw. Has individual throttle "velocity stacks" inside and throttle response is great with a GT3540.
does it come complete to install, if not what is required?
thanks for your speedy response.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
