Hi all fairly new to SAU, just got a few questions if anyone could help??? recently bought my 2nd R33 for 7K, it used to be a non turbo auto, but is now turbo manual... not sure weather the turbo just got slapped onto the N/A motor or if it's had a new engine, it's done 157,000kms and i've replaced plugs, oil, added a cooler and lowered the boost from 9psi on a bleed valve back to the standard 5-7psi solenoid... my main question is after a the car is fairly warm about an hour of driving it nearly has no oil pressure and when i get into it, it has a really bad misfire like it's detonating... any ideas or feedback would be much appreciated???
https://www.sau.com.au/forums/topic/267741-low-oil-pressure-bad-misfire/
misfire and detonating is 2 different thing. Does it stutter or runs, idle badly when you put your foot down?
When you say low oil pressure, how low are we talking about? Oil pressure suppose to drop when the car is warm'd up. Does the warning light come on?
I would clean and check the AFM, coil pack 1st, then air leak. It could also be a air leak somwhere causing it to run rough. Really need more details m8, it could be a combination of a number of things.
Edited by __PhaseShiftDown
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
