Hi Fellas,
A simple question, yesterday I was cleaning out my ACC, and when I was putting it back on, I kept tightening the bolts it but it never seemed to end.
I could feel it was on tight, but as a kept screwing it didn't feel as though it was getting progressively harder to screw, but it was still fairly hard, do you get what I mean?
In any case, have I F$%ked something up?
Could there be a leak between the plennum and the ACC valve now that this has happened, and if so, how can I tell if there is a leak?
I am one paranoid mofo!!!! WOOWOWOWOWOOWOWOWO
Any help would be great
https://www.sau.com.au/forums/topic/267760-how-tight-to-do-up-bolts/
It states in the manuals the torque settings, for the AAC Valve it is 6.3 - 8.3Nm which is fairly tight, best thing is to get yourself a torque wrench so you can be sure its to manufacturing standards :O
mm, but I got a plazma man plennum, maybe because it's aluminium it's different feeling now?
you need to be careful screwing into aluminium, the chances of stripping the thread is increased, you dont want to do this!
yes it will feel different, more "spongy" if you like
personally i would do it up until you can see the aac valve pull all the way up onto the gasket then maybe another full turn or two, depending on thread pitch
plumbers tape is a thin white elastic tape also known as teflon tape. you just stretch it over the bolt that u tightening and then screw it back in. most times, a couple of times round is heaps.
can buy it from bunnings, super cheap and even auto bahn.
Edited by cheez
ahhhh shit, I turned it like 5 turns after it hit the gasket........
Does this mean it's gonna leak now?
if its still tight...possibly not, but always check the pitch on the bolt first, say the pitch is 1.25mm, (assuming im correct) one complete revolution equals a movement of 1.25mm, so 5 turns would work out to be 6.25mm of movement!
Edited by Zurlox
Ahhh bugga, not to worry......
How will I know if it's leaking pressure?
You will probly hear it hissing...
Why dont you wind the bolt out and put a new one in?
You could have also stretched the thread, and when they stretch too fat they go bang, and you have half the bolt in your hand :O
have u go the correct bolt in there?
a 5mm will turn forever in a 6mm hole
Yeah it's definately the right one, it just feels different mounting it to the alloy plennum.
As that other fella said, feels spongy instead of getting progressively tighter.... I think it should hold up. I'll test it tonight see if I get any boost dropping off.....
zurlox, 6.3 - 8.3nm isnt tight at all... probably only a little bit tighter than u can do with a screw driver.
if its turned more than twice in aluminium then its nearly deffinatly stripped the thread.
should spray water around it when its running and see if it leaks. if its turbo then the boost could force it open then there will be a leak
i think best bet would b to find sum1 with a thread tapping set and re tap it and fit a new bolt..... but if the threads totally gone then u might have to get it inlarged to the next size up as there will be nothing to tap.
or mayb get a helicoil put in????
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
