About to order some bc's for my stag, sick of shitty slammed springs making me bottom out practically every day. I do like a fang but my 180s for that, do you guys recon 12 kg's all round I like what zei said hahah
12kg's are fine for the front.....12kg's are a too hard for the rear imo.....but then again I'm try to get a lot more power to the ground than stock.....I'm running 9.3kg's in the rear atm and it's very snappy in the wet........12's in the rear would be a little bumpy as well.
In between 8-10kg's would be fine in the rear....if you want to play around with it more get a good adjustable rear sway bar.
What springs you got? I wana bottom out.... :(
I'm still trying to research what's the best suspension to use to go low. BC are cheap and go low, but how low? Then there's StanceWorks ZeroClearance coilovers for the 350Z which are built to go low not for performance, but they're a little more pricey.
the BCs can go low. VERY low. check out my display pic, that was the height they came out of the box, looked awesome, but impractical. there was plenty of thread left to go lower, and also higher, which is where i went lol
So what's a practical yet low height (in mm/cm) for our cars?
in your avator pic - is that 10cm off the groung?
nope its more like 8cm off the ground lol
mine is a practical low height where its at now. but the back needs to come down a little, to pull the front bar up slightly as its a tiny bit too low
So how high is it off the ground now?
Where yours sits is where I want mine, possible lower... My chassis will have to grow balls of steel for the speed bumps into my workshop!
HAHahhaahha... I'd really like to see how low your car is going to be and how much damage you are going to do to the underside. :blink:
one braces the bottom rear of the rear subframe. another between the rails just in front of the rear sway bar, and another at the front binding the two black bar things that bolt to the bottom of the front suspension behind the rack.
they all sit higher than the lowest parts of my car - stupid factory mid muffler the size of my house
This one's on SilkRoad's. Top arms hit body, can just fit a match-box between the ground and one of the arms.
I intend to get a new exhaust made up to sit a bit higher, build a sump-guard and modify the rear setup so everything sits a bit higher, so I can drop it lower.
If only there was a sway bar group buy going at the moment... :whistling:
What handling? TBH, on the road the Stagea is always going to be a big wagon... for the moment when I want handling I have the RX7, my Stagea will be my impractical daily driver that shouldn't be a daily driver, until it gets ripped up. :D
lol fair enough!
being that low all your arms are at the wrong angle and having no travel left in the suspension means the ride would be harsh!
anyway, like i said, looks the goods. i still love the pearl white in the M35........ should have bought the RS aero in pearl white that i looked at
Yeh, i'm regretting not taking the time to check out other Stagea's before I got my one.
I had jsut sold my Forester and wanted a new car, and dad(importer) had just bought this one in, took it for a drive, and instantly fell in love. The modern tidy interior, the standard handling, the sound, etc..
If I had of known the turbo one's were so easily available, or the manual ones were out there, I would of tracked one of them down... Now i'm stuck with the poor-spec.. Oh well, it's kind of motivation to do something radical to it, knowing I cant make it any slower than it is now haha
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
