yup the softest setting on mine is pretty pussy, but its firm, like a new car.
i run mine around 7-8 at the rear, and about the same at the front, maybe a little softer so it doesnt rattle the entire front end off the car
It's always interesting to see the differences in peoples preferences, even when using very similar set ups. Stiff is not necessarily fast; but it can often give that impression.
I'm running 3 clicks in from full soft on the rear, and fully soft on the front. Before fitting my Sway Bars, I was running 3 clicks in from full soft on the front to get some bite on turn in, but once I had the bars on, I found the front wanted to follow every groove and was just too "darty" on turn in and had to soften it. I'm not running any Preload on my front springs as I feel it only adds to the bouncy feel (springs pushing back too hard on rebound) some people find with coilovers.
I still have stacks of bite on turn in, but the front end is much more compliant over choppy stuff and I believe it has more "feel" and is quicker in corners now. I think if you set up too stiff, you don't allow the weight transfer that is needed to get good mid corner grip and feedback. You just end up with a really sudden transition to understeer/oversteer; especially in wet conditions.
Like I said, not saying anyone is right or wrong; but I'm interested in others opinions in this regard.
Cheers, Dale.
Front 10kg/mm, rear 12kg/mm. That's the BR's, not sure about the V1's.
I'll go the BR's as there isn't much of a price difference.
Also where do you get adjustable bushes for the standard arms?
Cheers.
Cheers.
Are you getting yours thru Paul at Street to Track (www.streettotrack.com) ?
Price via him is $1,165 delivered. He won't sell the V1's, only the BR series.
Cheers.
http://www.superpro.com.au/find-superpro-parts-for-my-vehicle?listMake=51&listModel=334&listSeries=485&button=Search+Now
Whiteline do replacement bushes, but no adjustable one as far as I know.
I was just going to go through just jap, has any one purchased through Paul?
Just got a quote from Paul, he's down to $1155 for the BC BRs. Got to love this dollar at the moment! 10 days delivery.
At that price, why would you buy V1s from Just Jap? They want $1149!
I need to do mine sooner rather than later, it just wallows awfully. Really ruins the great effect of the swaybars :(
Hi guys, been trolling through this thread for some time trying to find info on AXIS suspension.. but that aside. With all this talk of kg rates for fronts and rears.. doesn't ride quality also come down to rim size and tyres? I have 35 series tyres on 20" rims (came with the rims) with stock suspension. while being quite comfy it will still jar when hitting bumps and holes and will hop badly if taking a corner in a spirited manner :P and hitting a bump. Shouldn't there be a balance between tyre sizing and suspension tweaking? I know when I finally get my head around this car I will definitely be changing tyre sizes (maybe even rim size) and then try to balance the suspension to suit my driving. Not that there's much selection for the AXIS :(
So just in case I've missed something, is there anything adjustable available for the AXIS??
I think AXIS is the same as any other NM35, so you should be fine with the BCs.
I know what you mean with tyres, found the same thing when I bought a car with 17" 35 series. Awful ride. Hated it. I'll be putting 18s or 19s on mine, the biggest I can use while maintaining 40-45 profile.
Funny thing is my parents have an Audi they bought with 19" 35 profile tyres, and the ride is fine.
IMO it does.....low profile IMO can look better(sometimes) but does mean better handling......I don't mind having a bit of a sidewall on the tyre not only to save the rim but to also stuff around with pressures to ensure the best response from your grip level in all circumstances......a bumpy road with 35 series tyres at speed can end up pretty messy and usually slower that 45 series tyres......naturally this all depends on the tyres your running!blush.gif
I thought i was in the same boat as ARX owners, being that we have HICAS and the wider track and higher stock suspension. I see the 'non ARX' note on each set of suspension and so fear the worst.
what width tyres are on the Audi? If they were like 335's or something killer like that the 35 profile would be much thicker than on our 225's and 235's
I'm actually thinking to change my rims to something smaller, maybe slightly wider and definitely thicker. I hate gutter bash so need bumper bowling tyres lol
agreed on all counts. sidewall definitely helps keep power to the ground, look at street drag radials. they can hook 1000hp no problem.. and its street legal! If the Stagea wasn't 4wd I would love to put a fat tyre on the rear, both for ride and handling
Axis is the same as RX and RS models for suspension.
RX and RS can both have HICAS.
Sorry mate, RX never had hicas as an option.
and AXIS has lower springs and different shocks, but yes the suspension is setup the same.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
