they are different, hence the requirement for a spacer in the rear fork of an M35 when using the BC coilovers, as i believe they use the same rear strut for both kits. no biggie, thanks to dale who supplied some large washers to make up the gap!
No shit.I have to find out what scott got me then. Works well though..
Wicked, this opens up more options then..
Daiyama and Tanabe are a fair bit cheaper than BC, but only made for Z33
Cheaper but is the Quality as good as BC's, for $1299~ shipped, I think they have the most comfortable ride I have ever witnessed. After I tune I think I know whats next :)
setting the dampers on mine on its softest setting, it was a tiny bit firmer than stock, very nice though!
i like it a little hardcore than that, so i clicked it over four times :P
nice, the time will come when i shall invest in some BC's,
I reckon the car feels abit better when the dampers are a little higher, not rediculous though, just enough... but can understand those with wife and kids that would complaint.
ooooooook so do we agree that after market coilovers made for V35/Z33 will fit into an M35 provided a spacer is used?
seems as though mate. Iaiaiaiaiaiaians definitely gotten em in!
well, i dont have V35 coilovers in, the fronts are totally different.
i have a kit for M35 4WD, its just the rears are almost the same as a V35. DONT buy V35 coilovers and expect them to fit, unless you have a PM35 RWD
Can someone here advise if it will be all right if I purchase the lowered springs on IM only? I'm trying to find a cheap sollution instead of buying the whole kit at once.....
Has anyone done this? which springs were used?
Cheers,
Fabio
Cheers,
Fabio
Cheapest way out is an angle grinder. :devil:
My suggestion is to wait and save up for some BC's as your shocks are surely on their way out by now anyway.
If you really want to waste your cash, try King springs, they make a set for the v35/350z which should fit but may be a little low for speed humps etc, mainly due to our long wheelbase. You may be able to ask for slightly firmer rear springs.
Cheers,
Fabio
Far better to buy a full kit as the struts give the stability to your suspension (particularly regarding rebound).
Unless you want to be lower to the ground and still bounce like a yo-yo :P
Yahoo is a great place to buy used and new stuff for our M35's and Aaron and the guys at Import Monster can certainly be trusted with your purchases.
I bought my Nismo's (among many other things) through them. Easy, great service and you can see the price breakdown before purchasing :thumbsup:
I guess it's worth doing all at once.... an adjustable probably is the way to go I guess....
Thanks for your reply.
Cheers
Grinder... haha
I just bought a white Stagea like yours in Japan and it's on the boat at the moment... it has 74K genuine kms... car used to be owned by a family hopefully suspension will be tidy....
quite keen to do wheels, suspension, exhaust... but I guess i'll take it easy otherwise I'm in trouble with my wife....
You seemed one of the most experienced and knowledgeable here therefore I was wondering if you could get back to me with few answer.... Sorry it's not related to suspension...
I'm about to take my car for compliance at Northshore Prestige any advice? Should I check transmission fluid? How much am I looking at for a custom made exhaust system?
Cheers,
Fabio
Fabio, my Stagea was complied by Northshore 4 years ago and I have seen the results on a few other M35's. They do an awesome job, can't really fault them at all. Oh, and they do the cleanest job with the rear anchor/restraint points that I have seen (no leaking for reckless hole drilling).
Grinder... haha
Cheers,
Fabio
Ive heard Northshore do one of the cleanest compliance jobs, unfortunately mine wasn't done by them. Cam, I have worked out it was the silicone blocking the drain lip that caused the water ingress, all fixed. :)
Get on Import Monster and look for a cat back system, I can make a dump for around $450 but you will need to get the front pipe made up locally (unless you come to Melbourne).
All fluids are supposed to be changed at compliance, make sure whoever does it uses the Nissan matic J fluid or Nulon synthetic, you cant use dextron 3.
For suspension look closely at the BC's. Great value for money.
  • Like 1
Thanks for your prompt response.... much appreciated the info...
cheers
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
