New Project
Hi All,
I will be coming home to Aus in about 2 months and have 25-30k to play with.
I want to get your advice to see if the following is achievable for my budget.
1) find a clean 32GTR with a good engine
2) Possible respray over stock color - freshen the look up
3) new rims, 19inch deep dishers
5) possible leather interior retrim
Can it be done?
Cheers!!!! :O
Hi All,
Can it be done?
Cheers!!!! :O
I think you will be looking at close to 35k for that, depending on what kind of respray and parts you want...
Hi All,
Can it be done?
Cheers!!!! :)
Surely the interests of good taste would dictate that it not be done? :O
ha ha!
I want it to be a classy streeter, usual gfb, bov, front mount, k&N etc.. all that stuff can come later + most gtrs allready have that stuff on them by now anyway..
The respray will just be going over the stock colour, just to fresh'n it up, and the leather will be good quality, not crazy hide, but nice stuff.
the rims, i guess will cost about 3k with rubber.. i think it can be done.. ??
Any tips on how to find a good engined 32gtr? I want it to be reliable, so not overworked, how often to these engine need a rebuild?
any gtr special engine check places etc??? just dont want to buy a bomb and have to spend 5k on a full rebuild!
maybe look at the importers... j-spec and prestige motorsport, theres heaps out there
www.carsales.com
www.carpoint.com.au
use the search functions there....
ive seen good R23gtr's for 20 grand, and thats worked too, so im sure you will find something....
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
