Ok, have an RB26DETT R32 Skyline, was working wonderfully until 2 weeks ago.
Went out with a few friends on the Sunday, off to the RSL for some drinks, some pool, and just to enjoy time with mates.
Went home, car was brilliant the entire time, no issues, good power delivery, a pleasure to drive.
Woke up the next morning, did the usual thing, got to car, unlocked it, fired it up, opened the boot, put my crap in the boot, came back, checked all the warning lights where off, there was no un-natural or abnormal sounds, spent another 20 - 60 seconds putting on seatbelt, changing radio station, and setting everything up to drive to work (the general morning ritual to allow the engine some time to get the oil around and warm up.
This morning, all was good, drop out of the drive nice, and I did the usual crawl until the termpature gauge started to rise.
Once the temp starts to rise, I went to put some more power down, but it didn't feel right, it struggled to pick up.
Checked the boost guage and it was pushing into positive boost, but struggling, felt sluggish, nd the exhaust note wasn't correct.
At this point, I dropped the mrs off at the train station, and took the car to my local mechy.
Did a compression test, 155psi +- 4psi on all 6 cylinders, so compression was sweet, and on went the diagnostics.
Today, he calls me saying the turbo was loose on the back, he has tightened the turbo, and is going for a test drive. After popping in to see him (he's a good friend), turns out the car shut down on him during the test drive and he hasn't had a look at it, so we both push it into the workshop, remove the coil packs, remove the plugs (covered in fuel) and do a compression test, and it's dead 0 on all 6 pistons.
I am at a loss, I can understand something going wrong and loosing a complete piston, but to loose all 6 is just not right.
We removed the cam covers to make sure both cams where turning when the engine was being turned over, and they are, so it's not a broken timing belt that has left the valves open.
Did ECU diagnostics, it revealed no error codes at all.
I am at a loss for idea, anyone else had issues like this or could help me out???
Thanks,
Brian.
https://www.sau.com.au/forums/topic/267835-instant-death/
  • Replies 46
I can't understand the compression dropping on all 6!? Maybe it's a fluke and the compression tester crapped out on him. Maybe try it on another vehicle??
As far as fuelled up plugs go, to me that points to ignition. Maybe the ignitor?
Doesn't seem to me that she should go like that so easily.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566352
I don't think even a popped head gasket would show 0 on all cylinders. Maybe it the belt slipped a tooth and trashed the valves into the pistons?
This is my thoughts, When starting to take the belt cover and CAS off, we found adjustable CAM gears hidden away inside, thoughts are that one of the cam gears might have loosened, causing the inlet or exhaust to go way out of timing, and thus mash the valves, leaving them not closing, thus 0 psi compression, which means no voilent combustion.
He's going to get his optical camera into the cylinders tomorrow and check the piston heads for signs of contact (camera doesn't bend back enough to see the valves themselves), and we can go from there.
Chances here are that head will be coming off, which means I might as well start looking at porting the heads, have a think about upgrading CAMs (especially with adjustble cam gears in there), and potentially high-flow the turbos while everything else is apart, but looking compression in all 6 pistons to me just isn't right, sounds like a timing issue.
Just glad it was polite enough to drive straight to the mechanics before bombing out, and it was nice it bombed on him, and not me.
B.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566373
Were they HKS cam gears? Contrary to popular belief, not everything HKS puts out is even half way decent. I have seen their cam gears kill 2 motors. They only have 3 little bolts holding them in place. Really need to crank them little buggers down.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566394
Before you take the head off you need to do a leakdown test. That will tell you why the cylinders are not making compression.
You can try something also.
Take the pipe off the plenum, cover it with your hand and get someone to crank over the engine. See if it tries to suck your hand in. Be careful you don't injure yourself. It can't swallow you hand but it can crack a knuckle :) .
I think, though, you will find the leakdown test will reveal your problem.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566395
Unfortunately they are HKS Cam gears, I did not install them, and didn't actually know the car had adjustable cam gears when I bought it.
I guess it's leak-down test time, and if this reveals mashed valves, it's a rebuild.
Bloody bad timing with a wedding in less than 6 weeks, but what can you do.
Thanks guys, when I find out more, I will post it up.
B.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566894
i would have taken the front covers off first & inspected the belt and timing before even worrying about the turbo if it was my car.
I also would have gone that route to check the cams instead of pulling everything else off.
I personally think the problem will be something odd.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566955
Well, crappy HKS gears sliding all the way to the extreme of adjustment on there own could throw it off enough o trash the valves while keeping everything still turning and screwing the rest of them up.
I would rather run cheap ebay knock off timing gears than those HKS pieces of crap. Unfortunatly, my cams have already been dialed in with them, so my HKS cam gears are going to stay put for the next couple months.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566956
Timing belt was checked when the car was first dropped off, thoughts at that stage was belt jumping a tooth, and tension arm failing, so the cover was removed, belt tension checked and found strong, belt in decent condition, so everything was put back together, compression test performed (156, 154, 155, 154, 153, 155), and then on inspection, the rear turbo was seen to be missing 2 bolts, and the rest where almost at the end of the threads, this is where focus changed on the investigations.
At this point, turbocharger was re-mounted, 2 new bolts fitted, and the car was taken for a test drive.
It was started, warmed up a little but allowing it to idle for a few minutes, and then driven around the block. It surged and dropped power, then gained power, then cut out completely (800 meters down the road from leaving the workshop).
It was pushed back. When cranking it over, it sounded higher pitched in cranking than normal, almost like it wasn't struggling to turn over (struggling against compression), so it was pushed back into the workshop, coil packs and spark plugs removed, and compression test re-done to reveal 0 PSI in all 6 cylinders.
B.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4566987
It's practically impossible to smash every valve when the belt breaks.
Once it breaks, the cams stop turning. It can smash every valve if the belt stays on but a bearing lets go causing the belt to loosen
Almost impossible although I smashed/bent 18 about 7 years ago when my bearing tension thing let go - could be a record... :)
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4567479
my tensioner snapped on sunday, thought id smashed the engine, i cranked it over to restart the car also. put a new tensioner on and bam all sweet, (vg30det) i thought my engine was interference but must not be, unlucky mate, just a thought but, if the cam gears cam loose surely they dont have enough adjustment to mash valves?
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4567631
bummer. my advice for ANYONE who fits ANY BRAND of cams gears is to check them 4 weeks after installation. being alloy there is always some 'give' in them. you tighten the bolts on installation but they can and do come loose. on one of my 32 GTRs. big build in japan. brand new crate motor, fully built from new, HKS turbos, 600ps all the good gear, cams, springs, head work blah blah blah. about 2 months after it was built we checked the cam gears. sure enough the bolts had loosened off. and these were tomei gears which run 5 bolts (i only use the 5 bolt jap gears, either tomei or trust). well worth checking.
https://www.sau.com.au/forums/topic/267835-instant-death/#findComment-4567874
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
