  • Replies 40
Well, best i could do :( Needs a clean haha.
Some people maybe wheel whores. But my dad was a brake whore :P - couldn't find the rest of the pieces.
Nice collection, just need a heap of cars to put them on now hahaha
Fark thats a nice collection you've got there!!!!
Those brembos look serious....
Couldn't help my self, picked up a set of brakes my self today...
Will upload pics tomorrow....
Oh nice one! Bring on the pics :D
Found out yesterday that my front are yet again not ready for collection, so those pics will have to wait until they're ready to be collected
Looks tough!
Where from?
Disc specs? They look like V8supercar
Got them off Britek Motorsport who had the calipers advertised on ebay.
They were off Jason Brights V8 supercar, last years car...
The rotors are genuine Alcon 378mm x 36mm front, 343mm x 36mm rear.
Pads are PFC 30mm fronts, Pagids 30mm rears.
Now how about we organise a group buy on the hats and adaptors to suit our cars??? :P
Oh nice one! Bring on the pics :P
Dont worry N1GTR, i got cars :D
I'm sure you've seen my AMG brakes on ezy34.
Nice alcon, looks like huge discs.
VERY nice work mate!
I think a gb is needed soon :) Ill be in 100% in 2 months time
Yeah have seen them, they look awesome :(
Ah Jack, have you looked closely at the configuration of the front Alcons?
No biggie, you will jus tneed to swap around the blee nipples and the fluid bridge, then quick trip to anodisers and you are set.
just roll the car over to bleed :P
mmm, ok, thats why your the brake king!!!!!
Im pretty sure they are mounted in the leading position, not trailing, so shouldn't that be the same as the skyline???
Oh well, will have to get them sorted. I'm assuming they are symmetrical, so each end is identical???
Either way the price I got them for I couldn't resist....
nope, look at the pics. see the caliper with the line still attached? it's the left front. it has the bleed nipple on the left of pic. so when on the car it will be pointing at the ground. no big deal though as troy said you'll need to swap the nipples with the bridge line so the nipples are up the top of the caliper when fitted to the skyline. :P
Faaark, that's too similar to mine!!!
Do you know the owner of the car???
Nah dont know him, just met him.
Was at a private HKS day at Sugo.
When i saw it i made a beeline for it, the body work was flawless. Really nice owner aswel
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
