Hey guys,
Just bought a used Z32 AFM and I'm a little worried its a fake as it has the Nissan logo on the side and I have heard some people say the dodgy ones have this. Apart from that the JECS sticker looks fine and the mesh is good(not sure what a 'bad'one looks like though).
I was wondering if I could test it easily by checking the voltage of my standard AFM under 0 load at idle and up to around 5000 RPM, then wire in the Z32 AFM and do the same. Am I correct in thinking that the voltage should be linear against the air flow, and that the reading of the Z32 AFM should be approx 20% lower than the standard? I just don't want to do the test and think its faulty then find out that they are both meant to read the same up to the certain point, then the Z32 starts to read lower after say 3v or so.
Also I know this will run the car lean for a second, will this be ok if I do it for a second while in neutral with 0 load?
Cheers,
ADrian
https://www.sau.com.au/forums/topic/267873-testing-for-faultyfake-z32-afm/
this is what a fake z32 looks like
youll note from the pics, the label is crooked, the mesh looks cheap and nasty
the unit works but the voltage is all whakco and runs like a bucket of crap
a legit Z32 should be around 0.5v at idle
should have an orange JECS label on it
http://paulr33.skylinesaustralia.com/photo...z32/page_01.htm
nah the nissan logo is on the plastic casting, i originally thought it didnt contain nissan
but it does, as jecs/bosch made AFMS for nissan
whats the issue with yours?
what car are you trying to use it on?
what happens at idle?
what ECU are you using?
you cant it with a stock ecu
Nothing wrong with it as I don't have an ECU to run it on yet, I just stressed out when I saw a thread about them and mine looked the same(Nissan logo, sticker has JECS at bottom left rather than ÚNISIA JECS CORPORATION however it doesn't look dodgy). I was just hoping to test it in some way before I payed for a tune then had to go back but I guess its a legitimate one. Might try to quickly hook it up at idle on stock ECU just to see what voltage it reads.
Edited by Kwyjibo
Ok just tested the AFM on standard ECU at stand still and logged the following voltages so if the AFM's are linear in their readings its a fake.
Standard AFM: idle - 1.1v
2000 rpm - 1.45v
3000 rpm - 1.7v
4000 rpm - 2v
'Z32' AFM : idle - 1.1v
2000 rpm - 1.5v
3000 rpm 1.7v
4000 rpm 2v
So can we confirm that the readings are in fact linear so I should be reading much lower at idle, like does it read lower only above a certain airflow(Paulr33 I know you said it should read 0.5 on idle but is this confirmed?)
  • 4 months later...
Just because it idle's or whatever doesn't neccesarily mean it'll work in my book
That way to interpret the results are,
- if its not 0.5v with ignition on (NOT idle) its definitely a fake, or stuffed
- if it is 0.5v with ignition on (NOT idle) it may or may not be a fake
So you can only confirm the negative with that test.
interesting, so the aftermarket oe REPLACEMENT afm's from bosch are no good? why are they a oe replacment?
putting a bigger airflow meter on with standard ecu is pointless. just like throwing a big four barrel on a mini... unless tuned you will go backwards.
also the voltage logs above appear to have no real gain in putting a z32 on? as its outputing the same voltage? ie it will max out at the same cfm as standard it would appear.
im obviously going to tune it. going to run a z32 with a nistune board. but i purchased a z32 afm the other day and only when i got home and started preparing the plug i noticed it is onli a 5 pin plug and socket, not 6. so is this a dead give away or do some come with the 5 pin plug, its in great condition, the sticker is straight and looks gen. i contacted the previous own how still claims is gen and said i can get my money back if im not happy. also doesnt have the nissan logo anywhere????
here r a few pics
The voltage logs were RPM vs AFM voltage.
Air flow is not always proportional to engine RPMs. Although the tests were done in neutral, putting the Z32 AFM on would have effectively changed the tune of the car and hence you could not say that load was equal on both tests.
The only real way to test it would be by comparing a known working Z32 AFM against the suspect one.
Even still, I wouldn't have expected the voltages to be exactly the same.
It could be possible that someone has gotten an RB20 or 25 AFM and put an orange sticker on it. I would say it's very likely since your AFM has a round shape 5 pin plug and Z32 AFMs have a square shape 6 pin plug.
have you messured the diametre of it?
rb25 and z32 are both 80mm so a similar voltage would be expected i spose.
also z32 is a old stlye hot wire design (thin wires in the airpath), where as 25 is a hot film design (flat plate in the airstream)
thats not a z32 plug... mayby a late model one? if its got 30p anywhere in the part number its a z32 series.
could it be out of a laural or something?
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
