Hey guys,
Just bought a used Z32 AFM and I'm a little worried its a fake as it has the Nissan logo on the side and I have heard some people say the dodgy ones have this. Apart from that the JECS sticker looks fine and the mesh is good(not sure what a 'bad'one looks like though).
I was wondering if I could test it easily by checking the voltage of my standard AFM under 0 load at idle and up to around 5000 RPM, then wire in the Z32 AFM and do the same. Am I correct in thinking that the voltage should be linear against the air flow, and that the reading of the Z32 AFM should be approx 20% lower than the standard? I just don't want to do the test and think its faulty then find out that they are both meant to read the same up to the certain point, then the Z32 starts to read lower after say 3v or so.
Also I know this will run the car lean for a second, will this be ok if I do it for a second while in neutral with 0 load?
Cheers,
ADrian
https://www.sau.com.au/forums/topic/267873-testing-for-faultyfake-z32-afm/
this is what a fake z32 looks like
youll note from the pics, the label is crooked, the mesh looks cheap and nasty
the unit works but the voltage is all whakco and runs like a bucket of crap
a legit Z32 should be around 0.5v at idle
should have an orange JECS label on it
http://paulr33.skylinesaustralia.com/photo...z32/page_01.htm
nah the nissan logo is on the plastic casting, i originally thought it didnt contain nissan
but it does, as jecs/bosch made AFMS for nissan
whats the issue with yours?
what car are you trying to use it on?
what happens at idle?
what ECU are you using?
you cant it with a stock ecu
Nothing wrong with it as I don't have an ECU to run it on yet, I just stressed out when I saw a thread about them and mine looked the same(Nissan logo, sticker has JECS at bottom left rather than ÚNISIA JECS CORPORATION however it doesn't look dodgy). I was just hoping to test it in some way before I payed for a tune then had to go back but I guess its a legitimate one. Might try to quickly hook it up at idle on stock ECU just to see what voltage it reads.
Edited by Kwyjibo
Ok just tested the AFM on standard ECU at stand still and logged the following voltages so if the AFM's are linear in their readings its a fake.
Standard AFM: idle - 1.1v
2000 rpm - 1.45v
3000 rpm - 1.7v
4000 rpm - 2v
'Z32' AFM : idle - 1.1v
2000 rpm - 1.5v
3000 rpm 1.7v
4000 rpm 2v
So can we confirm that the readings are in fact linear so I should be reading much lower at idle, like does it read lower only above a certain airflow(Paulr33 I know you said it should read 0.5 on idle but is this confirmed?)
  • 4 months later...
Just because it idle's or whatever doesn't neccesarily mean it'll work in my book
That way to interpret the results are,
- if its not 0.5v with ignition on (NOT idle) its definitely a fake, or stuffed
- if it is 0.5v with ignition on (NOT idle) it may or may not be a fake
So you can only confirm the negative with that test.
interesting, so the aftermarket oe REPLACEMENT afm's from bosch are no good? why are they a oe replacment?
putting a bigger airflow meter on with standard ecu is pointless. just like throwing a big four barrel on a mini... unless tuned you will go backwards.
also the voltage logs above appear to have no real gain in putting a z32 on? as its outputing the same voltage? ie it will max out at the same cfm as standard it would appear.
im obviously going to tune it. going to run a z32 with a nistune board. but i purchased a z32 afm the other day and only when i got home and started preparing the plug i noticed it is onli a 5 pin plug and socket, not 6. so is this a dead give away or do some come with the 5 pin plug, its in great condition, the sticker is straight and looks gen. i contacted the previous own how still claims is gen and said i can get my money back if im not happy. also doesnt have the nissan logo anywhere????
here r a few pics
The voltage logs were RPM vs AFM voltage.
Air flow is not always proportional to engine RPMs. Although the tests were done in neutral, putting the Z32 AFM on would have effectively changed the tune of the car and hence you could not say that load was equal on both tests.
The only real way to test it would be by comparing a known working Z32 AFM against the suspect one.
Even still, I wouldn't have expected the voltages to be exactly the same.
It could be possible that someone has gotten an RB20 or 25 AFM and put an orange sticker on it. I would say it's very likely since your AFM has a round shape 5 pin plug and Z32 AFMs have a square shape 6 pin plug.
have you messured the diametre of it?
rb25 and z32 are both 80mm so a similar voltage would be expected i spose.
also z32 is a old stlye hot wire design (thin wires in the airpath), where as 25 is a hot film design (flat plate in the airstream)
thats not a z32 plug... mayby a late model one? if its got 30p anywhere in the part number its a z32 series.
could it be out of a laural or something?
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
