Ceffy Suspension Settings?
konect
 Share
Hey gents,
I am wondering if you crazy drifters can post up you suspension settings that you are currently running? Pretty much everything on mine is set for grip at the moment so I'm looking for all settings such as (and any others I have forgotten):
Front:
Coilover stiffness
Camber
Caster
Toe
Rear:
Coilover stiffness
Camber
Toe
Thanks :P
Here's mine, mind you they aren't real aggressive set ups but they work in both the ceffy and laurel, and i've used the teins in both set ups
Front
7kg i think
2.5-3 degrees camber
6.5-7 degrees castor
2mm total toe out
Rear
5kg i think
1.5 degree camber
1.5mm total toe in
Cheers
Nick
 Share
