all wheels made in Japan..
ok first up..
15X6JJ 24+ 4X114.3 Globe wheels (Sigma Turbo) 2 are painted white, the other 2 were sand blasted almost 3 or 4 years ago....
2nd round
16X7 50+ 4X114.3 made in japan but no brand is marked (closely related to Tarmac's and are lighter then other 16's)
$150! firm w00t.gif (currently on hold)
final round
16X8 22+ 4X114.3 & 5X114.3 Sparco meshies (no center caps) used for my 5 stud conversion, 2 have gutter marks from previous owner (no structural damage), other 2 are perfect, comes with 205/50R16 Ventus K102's with 70%+ on all 4
i no longer have a 4studed car so the first 2 must go!! all wheels have no buckles and spin true..
MSN: [email protected]
hit me up an email, reply here or pm me...
pick up North west melb, or i can deliever in Vic for a kebab/pizza....
https://www.sau.com.au/forums/topic/267904-fs-assorted-wheels/
hey mate, do the sparco's clear 32 brakes without spacers?
cheers
i say it would, cause they were off a s13 with 5 stud conversion. not sure what brakes they used though....
sorry i should clear up, the Mesh rims don't have Sparco written on them, i forgot to put "Sparco Style Meshies" as the description, they are made by Asahi Tech Japan which is Japan's leading alloy manufacturing business (most Jap wheels probably use there materials anyways) http://www.asahitec.co.jp/english/
update
1st set on hold
2nd set sold
3rd set on hold....
Edited by JayRome
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
