Well i got new turbo's and changed it over with a friend of a friend.
Lets just say i can hear leaking of the exhaust manifold and the car is running unlimited boost cause i think he put the plumbing back in wrong.
So i was wandering if any one could, well re-install the turbo's i just installed.
Offcourse i will pay, so just wondering if anyone knew how to do it and how much.
Thanks guy's
Edited by black sky
https://www.sau.com.au/forums/topic/267928-replacing-turbos-on-a-gtr/
Thanks guy's
I'd say jus take it to a mech that specializes in turbos, they;d know exactly what to do. And i may be wrong but Im not sure if anyone on here wants to do a job that could potentialy mess up and end up costing u a lot more money than you'd pay someone to do. But yeah, if u kno how to do it right, you and your friend of a friend could go ask some mechanics for advise about the issue and do it yoursef,,will save u a bit of cash for more mods lol :banana: ..
good luck
ben
Edited by Benzino33
Where about's are you located ?
Thanks guy's
to do a changeover of turbos you looking at 800 roughly, old ones off, new ones on.. pretty tight area to work with especially if you havent done a gtr before.. its no ordinary commodore where things are a lot easier.. peace of mind dude!
hes asking for some one that might not charge 90 bucks an hour a home mech that has done it before who will do it for a cashy hey even if you charge 300-350 it takes you a day that's pretty good workshops charge way too much for spinning nuts and bolts in my opinion only thing i don't do on my car is tune it and wire it up.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
