Well, the dream might be over before it started.. I need $$$ and am looking for interest on my Iron Mask coupe.
All mods were carried out in Japan, they include:
Bride fixed back seat
Side mount rail
Nardi 330mm wheel
Safety 21 1/2 cage
Pivot shift light
Speed/rev meter
Greddy boost controller
Greddy turbo timer
4x Omori/greddy gauges
Cusco strut brace
Cusco camber plates
Old FMIC kit
HKS POD
Grex Oil cooler + filter relocation
Kakimoto 3 inch exhaust with front pipe
Bilstein shocks
Lowered springs
15x6.5 SSR Formula mesh
Damage: Drivers door caught on something while reversing - 2 spare doors are included. Aus spec guards can be had for around $60
It is uncomplianced but falls under the pre 89 rule, so in theory it can be registered.
Like most DR's it has some rust.
The ECU was changed from a standard unit to a Mines one before it was picked up by the car carrier and now it won't start :banana:
Recent compression test came out fine.
It has the late DR30 bodykit complete in vgc.
$3000 as it sits, or closer to $4000 for it running good
Not looking at parting out yet.. Sorry!!
[email protected]
Edited by D-limo
https://www.sau.com.au/forums/topic/267938-my-dr30-iron-mask-coupe/
  • Replies 64
Posted Images
Quite surprised in the interest generated. Price is revised to $3400 as is.. At that price I am just breaking even.
For $3400 I think its still alot of car for the money.
Car Now has a 350mm Nardi not pictured.
Is an Ex VIC car, Its featured on FJ20.com as well.
Ghostrider you have email.
Edited by D-limo
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
