The mines is out, gone for ever, it's in the boot of my Honda and it's up for grabs if anyone wants it.
Spec'd for DR30 with hi flo T03 as best I know. I will also have a PRofec Electronic Boost Controller, A speed Meter, The A/C but Benny wants that.
Grey over grey in near perfect condition door trims plus back seat is also going going gone
PM me if you want anything.
Cheers, D
  • Replies 64
Posted Images
Never heard of ADAPTRONICS before Dennis
How much are they?
$2500.00 supplied, fitted, wired & tuned and the Autronic SM4 is upwards to $4000.00 for same deal.
Have a look at this;
http://www.skylinesaustralia.com/forums/ad...;hl=Adaptronics
See what you think.
Cheers,
Dennis
First look under the car yesterday!
Sump looked like it had a head on with Ayers Rock & Oil Pick up was stuffed. Fixed this with another sump & pick up from SSS Automotive.
Rust is prevalent in front strut towers and spare wheel well and this will be repaired by welding plates over the damaged areas. Both sills appear to be solid at this stage so they will be treated with appropriate conversion & sealing products.
Otherwise it's a good thing and will make a fun & exciting car to drive.
Cheers,
Dennis
Hi Dennis,
Do you mean series 1 DR instrument cluster?
There were a few different types, depending on the power-plant in use. Can you elaborate?
I might have my old MR30 tail-lights stashed in the shed somewhere, I'll have a look
Ben,
Was thinking of the old barrel type gauge cluster.
Reason: The speedo & tacho panel is flat from memory and would be easier to mount a tacho & gauges, as opposed to the later quadrant gauge cluster set which is all individual units.
Cheers, D
You gonna get rid of the rails on the bride seat as well?
Probably, make me an offer ?????
The safety 21 half cage is out and up for grabs too if anyone wants. It's in the way so it's gone.
Cheers,
Dennis
Hey Dennis i pm,d you regards the Mines Ecu im still keen to get it! also the bride seat with out the rails
give me a packedge deal i have cash
Stay tuned folks!
I am out of the Oran Park track day due to illness, but an HKS Hi Mount manifold has arrived from Japan, a new bigger cross flow Delta Fin intercooler and 570/600cc injectors have been acquired.
Just a few more bits required and I'll be out at Wakefield probably for a testing session.
Some new pics minus the damage will be going on soon.
Cheers, D
Stay tuned folks!
Cheers, D
I will try and join you at Wakefield when my new toy arrives. It should be fun with 340hp and less than 1000kgs...
  • 3 weeks later...
Any track updates or anything?
Seat rails, not sure what they're worth really, $75?
When I last enquired I was quoted in excess of $400.00 for Bride ~ R30 seat rails.
I haven't decided yet, still looking at seating for driver.
Cheers, D
Dennis, you may want to look into a Sparco Evo XL (aka Evo 3) seat. They are 2.5 inches wider than a normal Sparco. Either that, or a RaceTech seat (the "W" is a wide seat). Both suit the "fuller" driver... :pirate:
BTW, I just may have what you are looking for. I'll let you know.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
