  • Replies 492
Posted Images
gotta love a bit of tech house
did you get some turntables as well as the mixer Craig?
I'm going to do a digital haul on Stompy.com this week. Gonna buy some of the latest deep house that hasn't been mass produced and is a little hard to find on vinyl
yeah mate. Got some stanton tt's coming this thursday.
CDjs coming this week depending on the cash flow.
This dude on ITM is selling a huge collection of vinyl. Hes got it all on excel . most for $6. Im getting a bunch of him. Nice guy too. have a look.
Got plenty of dubstep coming from the UK also.
Mainly gonna concentrate on tech house, prog. plus dubstep.
whats a good program to make your own mixtape? nothing fancy, just to mix songs into eachother as they finish/start.
burning via Nero will allow you to have no time gaps between tracks.....also another good thing is a middy mixer they pretty much give you a lot of control...mix and mash your own way....or you can just get some DJ's mixes like i do :)
If you just want to make a basic mix with some house tracks or something Damo, you can try NI Traktor DJ studio, basically two virtual decks with pitch, a cross fader, EQs, and some basic effects. You can record a whole mix set and it will write it for you as a wav file. Pretty cool to stuff around with.
Once you have the written wav file from Traktor, use Nero to burn it to CD - use the Nero Wav editor (like the guys have said above) to cut it up in desired spots, tick 'no pause between tracks' when you go to burn to CD. Ive been using Nero wav editor like this for ages when cutting up DJ sets and burning em to CD
Here is something from a very good mate of mine DJ - 2J
http://www.trancesa.com/mixes/Trancfixtion...(19-8-2009).mp3
right click save as :)
-Tracklist-
Skytech - Cardboard Box (Original Mix)
Smashing Pumpkins - Disarm (Randy Boyer Mix)
Sander Van Doorn Pres. Purple Haze - Bliksem (Original Mix)
Smart Apes Featuring Kate Miles - Smile (Michael Angelo Vs Silver J Catania Remix)
Bakke & Joni - Envision (Kris O'Neil & Simon Gain Remix)
Andy Moor & Ashley Wallbridge feat. Meighan Nealon - Faces (Original Mix)
Mark Norman - Coffee Break (Gustav remix)
Sean Tyas and Simon Patterson - For The Most Part (Marcus Schossow Remix)
Rank 1 - Symfo (Marcus Schossow & Robert Burian Remix)
First State feat. Anita Kelsey - Falling (Richard Durand Re-Work)
Sean Tyas - Seven Weeks (Original Mix)
Ronald Van Gelderen - Backstabberzz (Ummet Ozcan Mix)
Art Of Trance - Madagascar (Richard Durand Remix)
Rex Mundi feat. Susana - Nothing At All (Elevation Remix)
Ummet Ozcan Vs. W & W - Synergy (Original Mix)
Saints And Sinners - Peace (Breakfast Remix)
Woody Van Eyden - B.O.B (Ummet Ozcan Remix)
BeGold - Starstruck (Jochen Miller Remix)
Craig Gallon - 1186 (Ben Gold Remix)
Yeah i have dabbled with Traktor before, pretty easy to use, but i think it didnt let me record unless i purchased the full version? Nothing a torrent search cant fix :)
have a 'full' version of Pro DJ. Its pretty good. You can mix. add samples. basically like a real mixer. Minus the great effects etc.
You can also record direct to your harddrive in mp3 format or whatever your after.
Can send it to you. Might be on demonoid too
virtual dj mate.
there are a couple diff versions, but I guess they all do the same.
Remember Its a live mixing console tho. So youll have to sit there and actually mix the songs live and record.
Did you find it ? or you want me to dig it up for ya ?
there prolly is. Not too sure mate. Havent played with many comp DJ progs.
you should grab virtual tho. Youll prolly have some fun
Plus you can cut songs short if they get boring and blend in your next track. Live decks on the screen so you know what your doing. And a sorta simple beats per minute display.
what style of music you gonna record ? If its a dance beat. doof beat youll find it easy to blend.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
