hey all,
so im doing some planning and budgeting to get an r32 gtr in a year.. ive decided that i want to freshen the engine up anyway, so im wondering how often does an immaculate or tidy stock gtr come up for sale in japan with a dead or almost dead engine?? roughly looking at spending $10ish on the car and $5-10 on the engine... as opposed to buying a tidy 25g gtr and having it blow up the next day.. the rebuild will be using standard components, to standard specs, nothing fancy.. but just to give piece of mind.
are these cars even eligable for import or sale??
cheers
Linton
https://www.sau.com.au/forums/topic/267945-r32-gtr-with-dead-engine/
the price difference between an 'imaculate' R32 GTR and a 'tidy' one in Japan is considerable. so you would need to get a better idea of what you actually want before you start this exercise. $10k AU=JPY700000 [approx]; have a look on the auction sites and see what that will buy, definately not 'imaculate', probably not 'tidy' either. I imported a 32 GTR about a year ago and the import costs totalled approx $8.5k AU; that's car registered and on the road [not incl insurance]. so your estimate of $15-20k to import a good GTR and then reco the motor here, may need to be revised, in my opinion.
also, I can't understand why you would want to bring a 'dead' engine into Aus; better to bring in a car with a decent engine if you are intent on doing the import thing. otherwise why not just buy a car in Aus with a clapped-out motor and replace it?.
anyway, that's a heads up on my importing experience. good luck with it; there a great car!!.
thanks for the replies... i would prefer to find one in aus... however i want one in completly original condition. by tidy i mean straight.. paint will be being freshened up while the engine is out, bushes and some suspension components will be replaced at the same time.. basically i want a stock, accident free gtr, that doesnt have cutouts for strut braces, gauges mounted in the dash, 300km speedos, etc.. even if everythings stock, but clapped out.. most of it will be refreshed to make it like it just rolled out of the factory.
ive seen some here in aus for $25000 and some for below $15000... most of them however are modified.. $25000 to $30000 will get me a late model v spec.. but for 15 years it could have had a tortured life and the engine may give way on the drive home.. so id rather, for piece of mind, rebuild the engine and replace all the sensors, etc. ive seen one go for $10000 that needed a rebuild and some slight panel work...
time frame is not an issue, labour and workshops arent an issue.
i wasnt after replys on my idea... just if those cars ever came up at auctions..
you'd be better off finding one locally and maybe buying a n1 motor from japan to drop in?
that was an idea... but they are getting fairly thin on the ground.. i could get an r33 engine and go over it before dropping it in, but then it would be a 32 with a 33 engine... which doesnt sit well with me.. i think the original engine, provided its death hasnt cause too much destruction will be fine with a few new components... especially for what i want it to do, which is to sit in the shed pretty much.
thank you for the short answer... that was all i was after... i will venture down other paths.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
