  • Replies 186
Posted Images
any one got either the legalis or kakimoto
which do you reckon is better
either one of those to ill get
i want to get the takeros full titan yet the pipe is 100mm , larger then the desired 80mm for better flow as all the decate pipes are all 80mm as well
Takero's have discontinued the Full Titan.
If you want a huge exhaust, why not get a custom turbo-back unit made up?
no i am acyually thinking ill go with the kakimoto , down pipe and try find a 100 cpsi sports cat
should sound nice and thraoty and be just on the legal db rate
Edited by Sidius
where can i buy the kakimota n1 full mega from ?
is there the option to have the tempered tip to give that blue look ?
Kakimoto “N1 FullMega +Rev”
what does the + rev mean
also its illegal for front pipes these days due to the need for a cat ?
Edited by Sidius
If you wanted to get rid of the "bluing" you could always re-polish it.
If that's an photo of the actual system, it's still going to need a "mid"pipe, linking the dump to the front of the exhaust; it's almost another metre long, plenty of room for a cat.:cheers:
most of us have gotten/are getting scott to make from pipes as he can put a cat in it.
The +Rev is just apart of the name.
is the front pipe 80 mm pipe to suit the kakimoto also is the cat guna be a race cat so it flows better ?
if so im keen as for one
the kakimoto kit im looking at is a cat back exhaust
Edited by Sidius
its 3 inch. .125 mm smaller. 80mm SS pipes arent readily available - and if they are, its f'n expensive - so scott tells me.
the cats are usually 100CPSI race cats so highest flowing cat available.
speak to scotty about it.
far itl cost me $2073.00 for the exhaust including freight from fortyone automotive
any where else i can get these for cheaper
+1 for getting Scott to make one up... but you could always get the 80mm Kakimoto front pipe and have an exhaust shop cut and weld a 100ci cat in there.
Oh and Jesse Streeter will do it cheaper than that outrageous price you've been quoted.... as will RHDJapan (just email them as it is not listed on their website) or Import Monster.
ye contacted jesse streeter , hes cut that price in half
and im not sure i folow didnt you say the ones scotty is making is 80 mm piping , so that will suit the kakimoto exhaust
any one got a kakimoto on yet what are there thoughts
nah scotty makes 3 inch pipes which is 4mm less. bugger all difference. you may also need to get scott to make you a dump pipe.
mine should be here and on next week. and in for a tune the next few days after that. i can tell you what i think of the flow then. problem is, your never going to know how it flows until after a tune..
are you running the kakimotot exhaust thoughts ? as is at the mo
have you got one of scottys dump pipes ,
and ye i pmed scotty as i want both a fornt pipe with race cat and a dump pipe as well
dude i said its coming in a week. i havnt seen it yet.
yeh ive got one of Scotts dumps. proves to still be the best mod i did. there is a noticable power and response difference even at stock levels. he'll be doing my front pipe shortly, and will be making up a jig for the front pipes, with a 100CPSI race cat.
with his car they're proven for more than 300kw at the wheels.
you got a budget for your car or is it an as you go thing? be very mindful about where you want to go with your car. modding it proves VERY costly as our car is extremely different to others.
im just guna throw 1k at it a month until im happy with it , im going for a street car that i cant still take my misus and daughter out in for road trips , yet i want to put my foot down when im alone and feel a monster :P
no doubt. with mine tuned with emanage ultimate- and im sure two others will agree. cruising feels great, and with a foot down - feels insane! but u get a power bug that wont let you stop.
so do you guys recon the emangae ultimate is worth it ??
why not just go for a full link ecu replacment ... actuallly second thought thatll be to much effort and is only good for a full car build from bottom up
how does the emanage stand up against other brands of piggy back , is it highly recomended?
mite look at a emanage ultimate, what are the tuning posibilities with the emanage can you pretty much go to any power levels ?
exhaust
hdi intercooler to start with then go from there
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
