  • Replies 186
Posted Images
What do you guys reckon I've got here. I thought it was Cat back but I think it might be more:
Looks like a custom pipe/cat with posibly an N1 muffler
Pick from back (slightly under) of car showing the muffler will give us a better idea.
ohh mate that is a shocking exhaust, seriously get rid of it and swap it with mine :D
LOL at Mr. Desperado :laughing-smiley-014:
You really want an exhaust, ay?
Edited by iamhe77
What I'm after is not losing the free flowing nature of it but reducing the noise a bit. Also the tip is just way too big.
I'm thinking I may have to add something in to reduce the volume, maybe a rear muffler replacement is called for and add on a couple of pipes.
Rear muffler replacement for sure.
You could also weld up a resonator on the pipe after the cat (take a look at the Legalis for an idea).
to be honest if you want to change the rear can and install a mid muffler you may as well buy a new exhaust. im not saying that so i can buy your old one, but if you change enough, may as well change the whole thing, then you can make some cash when you sell me your old one. :)
well i got quoted 550 for a new catback custom made :D
got spec's?
You are hopeless man!
:D
+1 on that....pretty sure he would buy your grandma if she was cheep and up for sale!!!!
P.S. and no Ian I like my springs now!....got some AR-X standards for sale though with shocks!! :)
Houdini - u got more pic's of your dump pipe?
Edited by Jetwreck
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
